Old 07-05-2007, 02:42 PM   #1
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
Lug nut cover removal (help)
Okay this is not a blond joke but I need help. Went out to check my nuts (lug) how in the heck do you get the covers off. I have the Alcoa rims with the covers the po put them on and spent a pretty pretty penny and I sure don't want to mess the covers up.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 07-05-2007, 03:29 PM   #2
2004 25' Classic
West Chazy , New York
I check the torque of the lug nuts regularly and have yet to damage a lug nut cover. Just leave 'em in place and use a deep socket. I don't know how the covers come off anyway.
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Old 07-05-2007, 03:52 PM   #3
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
The dealer told me that they are not removable. I guess you just deal with them; I notice they wiggle.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 07-05-2007, 04:42 PM   #4
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
Ok guys,This ONLY applies to ALCOA wheels on motorhomes.They make a little tool just to remove the chrome covers.I don't know what its called,but it can be found at larger truck stops.They are around the truck chrome stuff section,by the lug covers.And Yes they do come off! If you want to make your own tool,just get a large pair of plyers,place a small piece of rubber (to grip) between the plyer teeth and the lug cover (both sides) and wiggle/pull the cover off.This tool (might) also be found for sale at semi tire shops,Goodyear/bridgestone etc... Hope that helps ya! Brian P.S. New lug covers are less than $1.00 each if you destory one.Take a undestroyed one to the truck stop and match up the size you need.....
wanderer1 is offline   Reply With Quote
Old 07-05-2007, 05:15 PM   #5
rebel beck's Avatar
1975 31' Sovereign
Images: 35
Thanks so much just what I needed to know, called our local truck center and they had just the tool.
Becky
Air# 9552
Old 07-05-2007, 07:35 PM   #6
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
No problem,glad to help!!! Brian
Old 04-23-2009, 11:18 AM   #7
BoJo's Avatar
2015 25' FB International
East valley , Arizona
Need help as well. Want to check lug nuts before next trip, so came to the forum to gather info on the subject. The lug nut covers are tight (couldn't remove them), however, one wiggles as mentioned in other post I read. When I tighten the lug nut covers, does this tighten the lug nuts as well; no need to remove the covers? Is that correct?
BTW, looked around RV supply places and auto supply stores for the lug nut cover remover. No luck. Next stop to shop for this will be a truck stop:}
Thanks in advance.
BoJo
2005 19' Bambi Safari LS
2009 Ford 150 Lariat
BoJo is offline   Reply With Quote
Old 04-23-2009, 12:10 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Hi BoJo. The shiny cover is not intended to be removed. Act like they are not there as you change wheels, etc. They might require an extended socket. Take a look at:
http://www.airforums.com/forums/f465...aps-42237.html
http://www.airforums.com/forums/f465...res-18460.html
5 meter Langford Nahanni
Old 04-23-2009, 03:16 PM   #9
BoJo's Avatar
Thanks, Bob. I'll get an extended socket. Appreciate your response.
BoJo
Old 04-28-2009, 08:46 PM   #10
richinny's Avatar
2011 34' Classic
many times the covers are damaged by incorrectly using metric sockets on (standard) SAE nuts or vice versa.
if you decide to try solid chromed nuts. i found that on my truck steel wheels, they tighten much more easily that steel nuts and they also loosen more easily. i don't think that is a good thing on a trailer wheel.
Ricky
Old 05-22-2011, 07:17 PM   #11
Capt W
2013 31' Classic
Jefferson , Massachusetts
This is such a great site. As a newbie getting ready to leave for Alaska, I tried my lug nut wrench on the AS and found the chrome covers to be as others have described. I've now outfitted the tool box with deep sockets and a good torque wrench. Thanks for posting the info.
Wayne
Wayne and Sarah
Welcome aboard, Mary Joan, the Tin Wheeler
http://www.tinwheel.blogspot.com
wrochdvm is offline   Reply With Quote
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
Strange nut Pahaska Windows & Screens 2 10-22-2002 12:47 PM
newbie looking to buy Oak All Argosy Trailers 13 10-11-2002 10:17 PM
cover for univolt maznblu Electrical - Systems, Generators, Batteries & Solar 2 09-15-2002 07:02 PM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
