Old 05-25-2008, 09:15 AM   #1
2007 25' Safari FB SE
Lake Forest , Illinois
Lug Nut Caps
I have a 2007 AS FB SE. I periodically check the torque at 110 # as that is what my manual and the dealer recommended. Today I noticed something that I don't recall seeing. The caps on many of the lug nuts seemed loose and I could move them with the pressure of my fingers. None the less the nuts torqued to 110 #. Are the caps a solid part of the total lug nut or could they be an add on to enhance the appearance? I could remove one lug nut and check for myself but with my mechanical abilities I thought I would leave well enough alone and not ruin the holiday week-end. I would appreciate your help.
woodedareas is offline   Reply With Quote
Old 05-25-2008, 09:30 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Allen. You've got it right -- those covers are for looks only. I believe the Classics have shiny solid lug nuts (stainless?).
5 meter Langford Nahanni
Old 05-25-2008, 09:31 AM   #3
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Yup...
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 05-25-2008, 09:44 AM   #4
Thanks Guys
I was so proud of myself for getting everything up and running until I ran into those caps. You have restored my confidence.
Old 05-25-2008, 09:44 AM   #5
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
I recently had some small warranty items taken care of at Jackson Center and they replaced 3 of the lug nuts that had cracks on the covers.
I was told that with the cover on they are inch (imperial) size but once the cover falls off you have to use a metric socket to remove them.
You are also going to learn to repack the wheel bearings each year, right?
SilverCottage is offline   Reply With Quote
Old 05-25-2008, 09:46 AM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I ordered my Safari looking wheels from Trailer Tires and Wheels - trailer tires, boat trailer tires, trailer wheels, boat trailer wheels, aluminum trailer wheels along with 24 of the stainless capped lugnuts. They are nothing more than stainless caps over standard lugnuts. Are you torquing the lugnuts with a standard socket or an extended socket attached to your torque wrench? I noticed that the standard 3/4" socket does not cover the entire lugnut so I am going to buy a 3/4 extended socket to make sure the lugnut to fully encased. If you look at the last picture you can see how the lugnuts I received from them end and the case is hollow inside.
ID:	60953   Click image for larger version
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-25-2008, 09:48 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Capped, at least my Safari is....
Looks like others are too.
Old 05-25-2008, 09:53 AM   #8
davidz71's Avatar
1986 25' Sovereign
Originally Posted by SilverCottage
...I was told that with the cover on they are inch (imperial) size but once the cover falls off you have to use a metric socket to remove them.
I'm going to use one locking lug per rim and keep the other 4 I ordered as spares in case this happens.
Craig
AIR #0078
3.73 rear end
Old 05-25-2008, 10:51 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Make it easier on yourself and go buy some chrome or stainless lugnuts and replace the ones with the caps. A cap will come off at the most inappropriate time (like changing a flat on the side of the road in nowheresville) and you won't be able to get the lugnuts off. IMHO the person who designed these lugnuts needs to be cut and bled out alittle.
Old 05-25-2008, 12:51 PM   #10
I did buy an extended socket and its works great.
Old 05-25-2008, 12:55 PM   #11
I actually did get the wheel bearings packed. That's why I was tightening the lug nuts. Just to be certain after I had driven a distance.
Old 05-25-2008, 03:14 PM   #12
_
hi wooded'
....I believe the Classics have shiny solid lug nuts (stainless?).
NOPE.
they are all "CAPS" even on the classics....
stainless over iron, but caps nonetheless, like the pix davidz71 offers....
several of the lugnutCAPS on my unit are loose or cracked at the inner edges.
the caps do serve a purpose,
they trap water and moisture INSIDE the lugs, which increases rust, sticking and bedevils accurate torque application.
recently i replaced a dozen with napa brand that are the same design.
there are SOLID stainless versions available, gorilla makes some really nice ones...
but they 3-4 times the price per nut...
cheers
2air'
Old 05-25-2008, 03:41 PM   #13
Anyway, they're cheap.
I remembered theVAP guys saying Tim Shephard's Ambassador project received free SS lug nuts. Not so. It looks like the contributor of his wheels gave him similar lug nuts. Guess the donor could afford it at $.86 each.
Old 05-25-2008, 03:48 PM   #14
_
....Guess the donor could afford it at $.86 each.
yep, and i'm looking for a donor for....
project 34, help me keep it rollin!
i only need 3 DOZEN of the high dollar nuts...
which are about the same price as one tank of diesel.
cheers
2air'
Lug nut size TheThreeSeas Wheels, Hubs & Bearings 4 04-17-2007 07:10 PM
Lug Nut Torque alan Wheels, Hubs & Bearings 46 11-27-2006 09:32 PM
Where do I get a lug nut socket Antique Pedaler Wheels, Hubs & Bearings 3 11-27-2006 05:59 PM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 12:24 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 12:27 PM
