Old 07-21-2014, 10:41 PM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Lug-centric or Hub-centric?
My wheels appear to be hub-centric in that they fit perfectly over the hub (pilot?) and fasten with lug bolts. Does this mean the lug bolts are not carrying the load the same as studs on a wheel? What I'm wondering is if at some point I would like to change wheels, would a wheel with a larger center bore work?
KYAirstream is offline   Reply With Quote
Old 07-22-2014, 02:23 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have never had any problems with aftermarket steel wheels with large center holes.
I have seen this discussion on some of the diesel truck forums but they are dealing with a different set of problems with power applied to the wheels.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-22-2014, 05:15 AM   #3
In your case were you using lug bolts as well?
Old 07-22-2014, 05:24 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Just the normal 1/2 inch tapered lug nuts. All my trailers have studs on the drums. I have seen some models that use bolts into the drums instead. Not sure it would make any difference if properly torqued but have not done it.
All my wheels are steel. I suspect that aluminum wheels would be more likely to loosen, but that is a guess, not based on experience
13 Ram 2500 TD
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts sepezlover Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
5 lug vs 10 lug wheels rollin home Wheels, Hubs & Bearings 0 08-03-2009 02:23 PM
Hub Lug and Circles Over59 Wheels, Hubs & Bearings 2 04-20-2004 07:05 PM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
