03-24-2015, 03:37 PM
1979 23' Safari
Las Cruces
, New Mexico
Lug Bolt Torque setting
I have a '79, 23' Safari. Is anyone aware of a preferred torque setting for torquing the lug bolts?
Greg
03-24-2015, 04:02 PM
1999 34' Excella
Hillsboro
140 pound feet should be good.
Are you running new lugs, lug bolts and steel wheels?
Peace and Blessings..
Channing
WBCCI# 30676
03-24-2015, 04:37 PM
1979 23' Safari
Las Cruces
, New Mexico
lug bolts
Currently and for the forseeable future it has steel wheels and lug bolts.
Thanks for your response.
Greg
03-24-2015, 04:56 PM
1999 34' Excella
Hillsboro
Tighten... Drive 5 or 10 miles, re tighten. Check again next day then every 4-5000 miles.
Channing
WBCCI# 30676
03-24-2015, 06:48 PM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Stamped on the head
Greg
Greg,
The Tq should be stamped on the head of the lug bolt. It should say tq to 110ft.lb provided you have the original axles with lug bolts.
That is the spec from the owner's manual.
Do as CWF suggests with the re-torque procedure until stabilized.
Lance
03-24-2015, 06:55 PM
Dallas
Just a curious question here. You keep mentioning lug bolts. Not lug nuts. My 63 Overlander has lug nuts. Do some Airstreams have lug bolts instead of lug nuts? Ala Volkswagen and other German cars with lug bolts instead of lug nuts.
03-24-2015, 08:34 PM
Always learning
1972 29' Ambassador
Central
Yes indeed.
Lance
03-25-2015, 11:27 AM
Moderator dude
1966 26' Overlander
Phoenix
Many of the 1960s Airstream trailers originally had lug bolts. (My '66 Overlander had bolts) The wheel centered on the hub of the drum and was secured with bolts.
I am suprised your '63 has studs and nuts unless the axle was replaced. And at it's age the axle should have been replaced.
>>>>>>>>>>>>>Action
03-25-2015, 12:42 PM
Dallas
Action: it's very likely that they have been replaced. They seem to be in good working order.
03-25-2015, 04:04 PM
Always learning
1972 29' Ambassador
Central
You may also have the original axles with new hub/drum assemblies.
Lance
03-25-2015, 04:41 PM
2013 31' Classic
billings
, Montana
80 to 100 is plenty....
