Old 03-14-2009, 11:07 AM   #1
2001 25' Excella
Rockport , Texas
lug bolt torque
Any thoughts on the lug bolt torque on a six lug aluminium spoked wheel on a 2001 25' Excella. Where would I find the specs and what is the pattern to torque them.
dosstx is offline   Reply With Quote
Old 03-14-2009, 11:24 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
The recommended torque values for your lug nuts should be in the owner's manual for you unit.
We have a 2005 25FB with aluminum spoke wheels and the the recommended torque value for my lug nuts is 110 to 120 ft/lbs. I split the difference and set my torque wrench at 115 f/tlbs.
When putting on the lug nuts, I put them all on wrench snugged. I then tighten the opposite sides first, and then the others.
When checking torque, I start at the top and go around clockwise.
Brian
SuEllyn & Brian McCabe
Old 03-14-2009, 11:37 AM   #3
2001 25' Excella
Rockport , Texas
I looked for the specs in the owners manual and all I seemd to find was the line "check wheel manufactures torque specs"........just wondering what the rest of you all use.
dj
Old 03-14-2009, 01:10 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The owner's manual for an '08 Safari says 120#. Thats for a 6 hole, 15" wheel. Might be different for 5 hole and/or 14" wheels. For 6 hole, pick a lug nut, get it lightly tight, go to the opposite one, then to one next to first one, then opposite that, etc. Then tighten each same way best you can since the wheel will rotate, lower to ground or lock the brakes and tighten to specs. For 5 hole pick one, go to the one that seem most opposite, then an opposite one, etc. If there are paint marks on the nuts and wheel, when you put the wheel back on, line them up the same way.
Gene
Old 03-14-2009, 03:17 PM   #5
hookedonclassic's Avatar
Fond du Lac , Wisconsin
My owner's manual says 95 lbs for aluminum or steel wheels.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 03-14-2009, 05:15 PM   #6
Master of Universe
Gene's Avatar
dosstx, given the variance in numbers, check the Airstream website and if you look around, you'll find people to e-mail with your question. Or, Rick March is the service guy and can probably answer your question: rmarch@airstream.com
Gene
Old 03-14-2009, 08:20 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Aluminum wheels should be torqued to 110-120 Lb/ft. The "proper" way is to torque all lug nuts in sequence to 40 Lb/ft, then torque to final value. Start at the top lug, then the bottom, then the next one to the left of the bottom one, then the one opposite that one, and so on. The 40# figure is not that critical, but the final value is. After initial torque, recheck after 10, 50, and 150 miles.
Old 03-15-2009, 12:01 AM   #8
georgezink's Avatar
1977 Argosy Minuet 6.0 Metre
Cape Coral , Florida
My aluminum wheels came with instructions to torque to 100# -- not originals however.
flcracker
georgezink is offline   Reply With Quote
Lug Nut Torque alan Wheels, Hubs & Bearings 46 11-27-2006 09:32 PM
lug bolt size airtim Axles 8 03-09-2005 09:55 PM
Correct Torque for wheel lug nuts? Cracker Wheels, Hubs & Bearings 2 05-30-2004 09:24 AM
How to replace lug bolt? frozen chosen Axles 1 05-01-2004 05:23 PM
Lug Bolt Size for '78 Sovereign dinoburb Wheels, Hubs & Bearings 2 03-20-2004 03:34 PM
