Old 02-03-2014, 09:59 AM   #1
2004 28' Classic
austin , Texas
Lost wheel and rim - may need new axle. Help sourcing Please.
On I-10, trailer swerved. Stopped and found our brand new SenDel wheel gone. New lug nuts appear to be sheared off. Luckily were able to limp half mile to Flying J in El Paso on 3 wheels. They are being helpful and think we may need a new axle. If so, any chance we will find a suitable one locally? There is a Camping World here. For our 2004 Classic, how do we find out what axle we need. Check the book? Call Airstream? I will search the forum too but thought someone out there might have advice. When our adventure is over, I will get my husband to post about the necessity of checking lug nuts frequently.
Ntex is offline   Reply With Quote
Old 02-03-2014, 10:02 AM   #2
2004 28' Classic
austin , Texas
Oops..should have posted this in the axle section...feel free to move it.
Old 02-03-2014, 10:03 AM   #3
timmaah's Avatar
1999 25' Safari
On , the road
Lug nuts attach to posts on the drum which can be replaced separately of the axle.
I believe the axles are made by Dexter and may take 6 to 8 weeks to get one shipped to the location. The last person I know who needed a new axle got one built by a local axle shop.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 02-03-2014, 10:03 AM   #4
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I'm so sorry that happened to you! We got our new axles from Colin Hyde and had a great experience.
Skatiero is offline   Reply With Quote
Old 02-03-2014, 10:11 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Get an expert opinion. Camping World or Flying J is not a place I would look. Call Airstream, Inland RV,(Andy) etc. Once you get their input you can probably get one on that area. An axel can also be ordered and installed by good trailer shops...ie., horse trailer dealers in that part of Texas. Much cheaper than RV dealership, for the most part, and usually a full service. Th
ey deal in 75,000$ trailers everyday. Don't discount suitable replacement axles. They come with complete assemblies...axle, brakes and hubs. Southwest Axle and Redneck RV Supply. Overnight from Dallas.
Then....you can travel some distance on three tire/wheels/. Just monitor your conditions.
Old 02-03-2014, 10:21 AM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You should be able to remove the drum. Drive out the broken studs, drive in new studs, install new wheel and new lug nuts and be on your way. If the stud holes are damaged, you may have to replace the drum, which will come with new studs.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 02-03-2014, 10:29 AM   #7
Gainesville , Florida
Too much torque?
Old 02-03-2014, 10:44 AM   #8
2004 28' Classic
austin , Texas
Too much? Or too little? Had them installed at local tire shop in Austin. Told them to use 125 torque. But never checked it and didn't check it after a day on the road. Lets just say there was operator error in failing to check.
Old 02-03-2014, 11:08 AM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The suggestion is after every lug nut removal is to check torque at 10, 20 and 50 miles and then daily.
Old 02-03-2014, 11:31 AM   #10
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
From our 2004 classic manual:
WARNING: It is also important to periodically check on the tightness of lug nuts. On
aluminum wheels they should he tightened to a torque of 85 ft. pounds. Steel wheels should be torque
to 95 Ft. Lbs. Care should he taken at all times when handling the wheel because of possible damage
to its appearance.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 02-03-2014, 11:48 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
125# of torque sounds like too much.
80-90# sounds more in the ball park for torque.
Are the holes in the rim best up? Are the rims steel?
If aluminum. Are you using the correct lug nuts?
Old 02-03-2014, 01:50 PM   #12
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
lost wheel
I pull campers out of Elkhart IN. When we pick up a new camper we have to torque lug nut and they use sendel wheels which we are required to torque to 120#. We have to torque when we pick up, 25 miles and at 50 miles and their are usually a few of the lug nut that have loosened up. If we don't torque and something happens we are liable for damages. 125# is right on the money
panheaddale is offline   Reply With Quote
Old 02-03-2014, 01:55 PM   #13
1964 26' Overlander
1968 30' Sovereign
Check torque values
http://www.airforums.com/forums/attachment.php?attachmentid=203297&d=1389379690
Old 02-03-2014, 02:47 PM   #14
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The thread is in the correct forum as the issue pertains to the lug studs and nuts which are part of the hubs.
What is the torque on the lug nuts for the other wheels? This may answer the question as to what the torque was on the lug nuts for the broken lug studs.
>>>>>>>>Action
split rim replacements '53 flying cloud rlmm Wheels, Hubs & Bearings 4 11-20-2013 02:08 PM
1972 31' Sovereign axle replacement SL4BLLT Axles 35 09-18-2011 08:56 AM
Grease on the wheel trmiller Wheels, Hubs & Bearings 6 09-11-2011 08:45 PM
What do these wheel numbers mean? Hummer Wheels, Hubs & Bearings 3 03-17-2011 11:09 AM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 07:50 PM
