Old 05-07-2014, 08:48 PM   #1
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Losing hubcaps - help!
Background: Axles are 3 years old. Wheels, bought from Inland RV are also 3 years old. Tires mounted and balanced, plus I use the Centramatic balancers. After losing 3 of the original full wheel covers on various trips the first year we had her back on the road, we decided to paint the rims blue and bought the dome hubcaps from Inland.
Name:	0608 wheels.jpg
Installed them in the June last year (2013), and went all summer on several trips, include one to New York and Massachusetts with no problems at all.
This year, I repacked the wheel bearings as I do every year, and installed the hubcaps before leaving for the Vintage Trailer Academy. Stopped after 100 miles or so, and removed the hubcaps to re-torque the lug nuts. Released I forgot my rubber mallet to put the hubcaps back on with. Used the heal of my hand to install the hubcaps, and they all seemed just as secure as using the rubber mallet.
Stopped for lunch, and two of the hubcaps are gone. Chalked it up to not having my rubber mallet, so they must not have been seated as well as I thought. Removed the remaining two so we didn't lose them on the rest of the trip.
Called Inland, and ordered new hubcaps (4, just be safe), and had them shipped to the VTA campground, Enchanted Trails. Great place to camp btw - nice friendly staff, wonderful desert campground. Picked up a new rubber mallet on the way as well.
Installed the two old hubcaps and two new ones before leaving the campground for the trip home. Used rubber mallet to install, being careful not to dent them.
Stopped for gas before stopping for lunch, and are now missing two hubcaps again!! One of the old ones and one of the new ones.
First time we lost hubcaps, one came off the driver's side front wheel, and the other came off the passenger's side rear wheel. This second time, the old hubcap came off the passenger's side front wheel, and the new hubcap came off the driver's side rear wheel. So, opposite wheels lost the hubcaps the second time around. Removed the two remaining hubcaps for the rest of the trip home.
Has anyone experienced losing hubcaps this frequently before? I'm at a loss to explain why they are coming off. All seem very snug and require a fair amount of force to get them to snap onto the rims, which is why I use a small rubber mallet.
I'm beginning to think the Little Girl wants shiny new shoes (aluminum mag wheels), but before going that route, I wanted to see if anyone has any ideas on how we can help ensure the hubcaps stay on, because we really like this look.
Chris
Old 05-07-2014, 09:12 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I like the look too. Those wheels and caps look great!
I am not for sure how the connect to the wheel, but I assume by the welded clips on the wheels, if so, maybe they need to be adjusted by bending them a little.
In my experience repops aren't usually exact, and they often need a little adjustment, and with hub caps even the thickness of the paint can cause fitment issues.
Old 05-13-2014, 08:58 PM   #3
1969 31' Sovereign
Rock Hill , South Carolina
Hello Chris,
Your problems of repeat replacement are daunting. I have a 68 Sovereign that I bought recently with no hubcaps. After your experience, do you still recommend buying them from the Inland company? Could it be that their supplier does not supply the exact replacement size due to stamping issues? Where else would you go to find them? I also lost a grease cup on the way home, same issue as yourself, palm hammer. Where might I find one for the AS 15" wheel. I've gone to 8 different shops in 3 states and no one has that size.
Cliff
popacliff is offline   Reply With Quote
Old 05-13-2014, 09:07 PM   #4
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
I have the opposite issue.
I bought a bunch of parts and in among the stuff were a set of hub caps. Never installed and brand new. Beautiful. Only problem is that I cannot get them to fit. I tried the heel of my hand and then moved on to a mallet with no success. They are just ornaments right now.
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 05-13-2014, 09:49 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I had this same problem many years ago. It was on a 1963 Fairlane station wagon, not a trailer. The problem was the steel wheels weren't made for radial tires [radial tires have so much more grip than bias ply and balloon tires] and flexed on turns. I lost several wheel covers on curved freeway on-ramps. I heard, and seen, a few of them as they flew off.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-14-2014, 09:23 AM   #6
Minno's Avatar
1972 31' Sovereign
Popacliff, The hub caps I bought, according to Inland RV, are specific to the wheels they sell. The wheels do not have welded on clips to hold the hubcaps. They have 3 lugs formed into the wheel that the hubcaps snap onto when you install them. Considering the amount of force I need to get them to snap onto the wheels, I'm still surprised they came off while traveling.
Bex, The hubcaps you have are probably not the correct ones for the wheels (rims) you have. While I haven't tried them, Vintage Trailer Supply also sells hubcaps. They might fit a different rim than the ones from Inland.
Robert, I had not thought of that. I do have radial tires on the steel rims. I wonder if that's the issue? We're heading out this afternoon, and I re-installed the hubcaps with my rubber mallet. Maybe I'll pull them off for traveling, and re-install once we get to the rally site.
We did order new hubcaps in a totally different style from a different company. They clamp onto the lug nuts instead of the rims. Unfortunately, they have not arrived yet, so we won't have them for this weekend trip. I'll post pictures once we get them installed, and update after our first trip with them.
Chris
Old 05-14-2014, 08:17 PM   #7
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
baby moons
You have an interesting mix of intrigue and frustration...
Steel wheels and baby moon hub-caps is a good look. To me, the only reason to change to aluminum wheels would be a set of first generation Center-line Auto-drags.
I can agree that not all “exact replacement” products exactly replace the product that they are replacing. Sometimes it looks the same, they say it's the same... I'd hate to think that a wheel center/bolt face was squirming enough to pop a hub-cap off. Wonder what is the inspection quality of hub-cap seat diameter and run-out of today's exact replacement wheel?
This isn't entirely pertinent, but explains some... I have four genuine OEM Airstream wheels for fitment to my 68 GT. One pair is1968, and has six riveted on spring clip hub-cap mounts. The other pair is Genuine Airstream from seventies and has FOUR nubs holding the caps. There is no interchangeability of hub-caps between these.Click image for larger version
The Baby Moons that fit my four nub AS wheels are a set that I bought from JC Whitney around 1974. I saved the limited fitment list from the box. The very accurate inside measurement that I took from these caps of which I am 100% certain is, 10.25”. They snap on by fist with a feeling of correctness. They don't fit loose. They have never come off by themselves. Require pry tool to remove. Click image for larger version
ID:	211930Click image for larger version
I saw hundreds of baby moons on eBay, but no 10.25” size. Closest reproduction size for sale is 10.125”. Maybe these pound on with a mallet. I wonder if your replacement wheels accept 10.125” or 10.250”?
I've had cars with loose nub style hub-caps that rattled but never came off. Maybe the added deflection of a 10.125” rim onto the 10.250”nub does not allow the rim to get over the apex of the nub and get a grip from behind it, or changes the angle of capture... loses its temper to grip when stretched? Paint? You definitely have an attachment issue.
Please keep posting, this is a good mystery.
Thanks, Wm
ALUMINUMINUM is offline   Reply With Quote
Old 05-20-2014, 11:43 AM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Steel wheels will flex. (Cast wheels not so much) Some wheels flex more than others because of the construction of the wheel. It really depends on the construction of the wheel and primarily the wheel center. Especially a dual axle making turns the pivit point will not be at the point the tires meet the road. So all 4 tires are being dragged around the turn which induces stress on the wheels. If the wheels are not fairly rigid the center will flex and pop the wheel cover off of the center.
The solution may not be in the wheel cover or cap.
>>>>>>>>>>>>>>Action
Old 05-20-2014, 02:02 PM   #9
Minno's Avatar
1972 31' Sovereign
I still find it amazing that we ran an entire season last year with these hub caps, including a trip to upstate New York and Massachusetts, without losing a hub cap. Now this year, we've had a total of 5 pop off the rims. The last one was as we were pulling out of our campsite Sunday morning. I heard it pop off and the trailer wasn't even out of the campsite yet. We stopped and I removed the other 3 and put them in the storage hatch for the trip home.
The replacement hub caps were waiting for us when we got home. Need to paint a bit more of the rims and then I'll post pictures of them. I put one on to see how it fit, and now I can't get it off! It clamped onto the lugs nuts really well I guess. I need to find or fabricate a small pry bar to get underneath the edge of the hub cap so I can pry it off the rim.
Chris
Old 05-22-2014, 04:41 PM   #10
Minno's Avatar
1972 31' Sovereign
As promised, here's the pictures of the new hub caps. While we like the look of the "Nurse Diesel" hub caps better, they're not worth it ($25 each) if we're going to lose them.
These new ones are very ok, and are only $6 each. They snap onto the lug nuts instead of the rim. Hopefully Little Girl will like them and she'll let them stay on.
Chris
Name:	0522 hubcaps 01.jpg
ID:	212517   Click image for larger version
Name:	0522 hubcaps 02.jpg
Old 05-22-2014, 06:19 PM   #11
Central , Mississippi
Those would look awesume with some beauty rings.
I also have problems with popping off baby moons on my 4 dimple rims. They will feel like they seated but its only snapped over 3 of the 4 lugs. I have to put them back on exactly as they came off to get them seated, a small black mark that lines up with the valve stem helps. I have them marked as to which wheel they fit onto.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 05-22-2014, 06:57 PM   #12
Minno's Avatar
1972 31' Sovereign
Beauty rings?
Chris
Old 05-22-2014, 07:35 PM   #13
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by Minno View Post
Beauty rings?
Chris
Chrome rings that cover the lip of the wheel rim.
Stainless Steel 15 Inch Beauty Ring, Smooth - Speedway Motors, America's Oldest Speed Shop
>>>>>>>>>Action
Old 04-29-2018, 09:15 PM   #14
1971 27' Overlander
Jackson , Tennessee
I am using this old thread as I think I have found an answer to my hub cap fit dilemma, and I hope it may help the others who posted.
I tried using the original wheel covers and lost one before I got out of town. Aluminuminum is right about the measurement: 10.25" on my Dextar wheels as well. After 2 failed attempts at "close enough" baby moon replacements, I finally found a true 10.25" at AutoAmenity.com. These are polished stainless (not chrome plated) at $84.50 for 4, free shipping. They snapped on perfectly, and come off only with nudge from a pry tool, not with bare hands.
I've been on 2 trips with these so far with no problems.
I hope this helps.
Alan
TennTex is offline   Reply With Quote
Water pump losing prime brhulen Plumbing - Systems & Fixtures 9 02-05-2009 10:31 AM
My Airstream is Losing Appeal! Smokin Camel Off Topic Forum 15 04-13-2008 08:38 PM
Losing Threads Zeppelinium Forum Admin, News and Member Account Info 11 03-10-2008 06:24 PM
Duramax/Allison Losing Power...??? dscluchfc Tow Vehicles 22 01-08-2007 06:57 PM
BAL stabilizers losing nuts? Kistler Jacks, Stabilizers, Lifting and Leveling 3 04-15-2004 06:50 PM
