Old 07-18-2011, 12:21 PM   #1
1988 29' Excella
Waco , Texas
Looking for a spare - 1988 Excella
I need a spare wheel and tire for my 1988 Excella. Does anyone know what wheel I need and the best place to find it? The wheels it has now are 6-bolt, but I don't know the rest of the specs. Where I expect to see a size on the tire I see 7.0 x 15, which doesn't look like the sizes I'm used to seeing on my cars and trucks. thanks.
crios is offline   Reply With Quote
Old 07-18-2011, 02:54 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The bolt pattern is 6 bolts on a 5.5" circle, 15" rim. Are you looking for a matching rim, or just one to keep as a spare that you don't mind looking different if you have to put it on the trailer? If you just want one the right size and bolt pattern, you can get one with a tire already installed from places like Northern Tool or a trailer supply. If you want one that matches your current rims, you'll probably need to find a used matching one.
Oh, and welcome to the forums!
— David
Old 07-18-2011, 04:48 PM   #3
1988 29' Excella
Waco , Texas
Thanks! I'm not trying to match the stock wheels, so I'll stop by a trailer supply store.
Old 07-18-2011, 04:54 PM   #4
richinny's Avatar
2011 34' Classic
i beelieve the stock wheel has a 2600 lb rating and zero offset. i'd also check the date code on those tires. most trailers have switched to radial tires for quite some time.
Ricky
Old 07-24-2011, 07:41 AM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I know I'm a bit far from Waco but I have 4 steel wheels ( sorry, no tires ) that I've taken off my AS that I will offer for free to anyone needing them and close enough to pick them up here in New Jersey. I recently put a set of Alum wheels on and have these available. If not off to scrap they will go. I'd rather see them go to a good home though.
If anyone is interested send me a PM and we can work something out.
Thanks all.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
1988 Excella 32' GVWR Confusion! Rob&Julie Towing, Tow Vehicles & Hitches 26 03-17-2012 02:06 PM
1988 Excella Inside Door Latch Broke 68Glbtrotter Doors & Locks 6 06-07-2011 11:53 AM
1988 Excella AC Drain Problem 68Glbtrotter Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 06:01 PM
Exterior Aluminum type for an 1988 Excella? Rob&Julie Ribs, Skins & Rivets 0 02-14-2011 08:04 AM
