Old 01-27-2016, 09:21 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Let's talk about valves stems
So I bought the Sendel T03 rims and I'm going to pull the trigger on the Michelins, but unfortunately I don't know what to do about valve stems.
I figure I need low profile metal stems for the TPMS, so I found theses:
http://www.trailerandtruckparts.com/...l#.Vqg5sq88Kh8
What do you think?
Ted S. is offline   Reply With Quote
Old 01-28-2016, 05:15 AM   #2
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I would be interested in what others are using. I tried two different sets of metal valve stems that would not fit my new tire rims. I'm sure they make them I just have not had luck finding them at local parts stores.
Ron
Ron A is offline   Reply With Quote
Old 01-28-2016, 06:24 AM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
The metal valve stems I have used on steel rims are similar to what is pictured in the link above. They should come with two different size gaskets to fit the different sized hole diameters in the rim.
Do you have a decent tire shop where the mounting will be done? They may be able to help.
You may want to call the rim manufacturer and see if they know the diameter of the hole.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-28-2016, 06:54 AM   #4
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Prescott Valley , Arizona
When I got my new rims I took them to Discount Tire to get the Michelins installed. I just told them that I wanted metal valve stems. They installed them at no additional charge. I don’t know what brand they use, but they work just fine.
AIRTRVL is offline   Reply With Quote
Old 01-28-2016, 10:32 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Dill (or other brand) TPMS with tire pressure monitors and metal valve stems...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-28-2016, 10:33 AM   #6
m.hony's Avatar
2013 30' Classic
...and don't forget the Centramatic balancers...
TAC #MS-10
Airforums #70955
Old 01-28-2016, 10:39 AM   #7
1970 27' Overlander
Carmel Valley , California
I purchased these Slime Valve Stem Extenders, shown here at O'Reilly Auto:
http://www.oreillyauto.com/site/c/de...0183&ppt=C0337
Slime - Valve Extender
Line: SLI | Part # 2045A
Chrome
1-1/4 Inch
Package of 4
DETAILED DESCRIPTION
Solid metal valve extenders make hard to reach valves accessible. 4 pieces. 1.25". www.slime.com. Carries the Slime Satisfaction Guarantee
ADDITIONAL DETAILS
Finish: Chrome
Length (In): 1-1/4 Inch
BRAND INFORMATION
Replace or upgrade old, worn and leaky valve caps and valve extensions.
They have worked fine on my 1970 International's original rims and caps.
asokolow is offline   Reply With Quote
Old 01-28-2016, 10:46 AM   #8
jackson center , Ohio
Also make sure of the pressure rating of the valve stem....80psi
Schu is offline   Reply With Quote
Old 01-28-2016, 10:59 AM   #9
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
I had Discount Tire install Dill VS-902-W valve stems on all my wheels, spare included.
See this page of the Dill catalog for a picture (need to scroll down):
http://www.dillaircontrols.com/files...s_page_3_4.pdf
Greg
greghoro is offline   Reply With Quote
Old 01-28-2016, 11:02 AM   #10
LeeJ's Avatar
1985 25' Sovereign
Okc , Oklahoma
Originally Posted by AIRTRVL View Post
When I got my new rims I took them to Discount Tire to get the Michelin's installed. I just told them that I wanted metal valve stems. They installed them at no additional charge. I don’t know what brand they use, but they work just fine.
I did the same thing two years ago, so far so good.
Lee Johnson
Corriente de Aire
85 Soverign
LeeJ is offline   Reply With Quote
Old 01-28-2016, 11:52 AM   #11
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
My tire dealer had metal stems where the washer was too big for the hole on Sendels. Had to go rubber.
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 01-28-2016, 12:42 PM   #12
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
When I upgraded to the Michelins and Sendal T03 I bought them through Performance Plus Tires and the put the metal stem in when mounted. Had to just ask for it. Suggestion I have is to make sure it's not a "shorty" as, depending on your TPMS, if it screws onto the stem it may hit your Sendal wheel. A little linger may be better.
Chuck
silverlabs is offline   Reply With Quote
Old 01-28-2016, 06:13 PM   #13
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I'm currently researching tpms' myself along with new valve stems. I found these that look interesting. They cost more, but they would make it easy to add air with the sensors in place.
http://www.tpms.ca/t-valves.html
Unless I get flow through sensors in which case they aren't necessary. Of course if I'm taking tires off to replace valve stems why not just get internal sensors. I think I've spent more time agonizing over a tpms than I did buying the AS!
Landrum is offline   Reply With Quote
Old 01-28-2016, 06:14 PM   #14
1967 26' Overlander
Spartanburg , South Carolina
What do you think?
When I bought my GYM's at our local Sam's Club tire shop, they put metal stems in without my asking.
Jacob D is offline   Reply With Quote
Old 01-28-2016, 07:01 PM   #15
2016 30' Flying Cloud
Blenheim Ontario , Ontario
What do you think?
I have a TPM, on my Airstream, (forget the name) and the front right sender would only work sporadically. So I purchased a set of two more, ($180 Cdn.) and STILL, the R.F. wouldn't work all the time.
After tightening it down on the valve stem real tight, it would work better, but not not perfect.
I finally figured out that the inner valve stem was not quite long enough to open the sender.
I have a new Airstream now, with new wheels/tires. I'll find out this Spring if that was the problem.
MelGoddard is offline   Reply With Quote
Old 01-28-2016, 07:17 PM   #16
Silverbee's Avatar
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Metal Valve Stems
I have the Einky product to be good and available through this company.
They were recommended by the makers of my TPMS.
https://www.shinyrv.com/store/c7/Ein..._and_Cars.html
Silverbee is online now   Reply With Quote
Old 01-28-2016, 07:26 PM   #17
2015 30' FB FC Bunk
i read that the goon ones should have a "TR" rating, I don't know what that is.
Einky look good, I for sure want good quality, the the new rims and Michelin's, I see how this could be a weak link.
Old 01-28-2016, 10:12 PM   #18
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
If your TPMS signals seem weak, you need a repeater. I know the ProPresure system repeater works well. Been on for 8 years.
guskmg
Old 01-29-2016, 04:18 AM   #19
m.hony's Avatar
2013 30' Classic
Or you need to use the supplied external antenna...
TAC #MS-10
Airforums #70955
Let's talk about Amazon some more... AIR-Quarius On The Road... 16 01-05-2015 03:05 PM
Let's talk Boundary Waters Caryl On The Road... 42 08-05-2009 12:05 PM
Let's Talk Batteries IrishRover2 Batteries, Univolts, Converters & Inverters 58 04-02-2007 01:24 PM
