Old 01-28-2016, 08:01 PM   #15
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by Ted S. View Post
So I bought the Sendel T03 rims and I'm going to pull the trigger on the Michelins, but unfortunately I don't know what to do about valve stems.
I figure I need low profile metal stems for the TPMS, so I found theses:
http://www.trailerandtruckparts.com/...l#.Vqg5sq88Kh8
What do you think?
I have a TPM, on my Airstream, (forget the name) and the front right sender would only work sporadically. So I purchased a set of two more, ($180 Cdn.) and STILL, the R.F. wouldn't work all the time.
After tightening it down on the valve stem real tight, it would work better, but not not perfect.
I finally figured out that the inner valve stem was not quite long enough to open the sender.
I have a new Airstream now, with new wheels/tires. I'll find out this Spring if that was the problem.
MelGoddard is offline   Reply With Quote
Old 01-28-2016, 08:17 PM   #16
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Metal Valve Stems
I have the Einky product to be good and available through this company.
They were recommended by the makers of my TPMS.
https://www.shinyrv.com/store/c7/Ein..._and_Cars.html
Silverbee is offline   Reply With Quote
Old 01-28-2016, 08:26 PM   #17
2015 30' FB FC Bunk
Ayer , Massachusetts
i read that the goon ones should have a "TR" rating, I don't know what that is.
Einky look good, I for sure want good quality, the the new rims and Michelin's, I see how this could be a weak link.
Ted S. is offline   Reply With Quote
Old 01-28-2016, 11:12 PM   #18
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
If your TPMS signals seem weak, you need a repeater. I know the ProPresure system repeater works well. Been on for 8 years.
guskmg
Old 01-29-2016, 05:18 AM   #19
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Or you need to use the supplied external antenna...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Let's talk about Amazon some more... AIR-Quarius On The Road... 16 01-05-2015 04:05 PM
Let's talk Boundary Waters Caryl On The Road... 42 08-05-2009 01:05 PM
Let's Talk Batteries IrishRover2 Batteries, Univolts, Converters & Inverters 58 04-02-2007 02:24 PM
