Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 04-10-2002, 10:21 AM   #1
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The Junkyard Wheel Story
Read the short story on the "JUNKYARD WHEEL." Go to inlandrv.com, click on articles, and then click on "THE STORY OF THE JUNKYARD WHEEL."
Don't let you or your family become victims.
P.S. Your Airstream won't like it either.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 04-10-2002, 06:04 PM   #2
apple 1
Profile:  1996 30' Excella
Brighton , Michigan
Andy,
Great story which everyone should see. New wheels are not expensive.
Also everone should inspect there wheels on a regular basis. Last year I had to replace one wheel on my '96 trailer which was developing radial cracks from the bottom edge of the triangle hole. This wheel had 4 equally spaced cracks around the wheel. Each crack was 3/4" to 1" long. I now inspect the wheels on the return from each trip. Just returned from Florida and when inspecting the wheels found another wheel starting to crack. Note both wheels still had the orginal load range C tires.
I also note Airstream changed the wheels from the triangle hole to a round hole mid year '96.
apple 1 is offline   Reply With Quote
**Broken Wheel Well** Silvertwinky Wheel Wells 8 05-26-2006 02:57 PM
What is your favorite "oops" story? yukionna On The Road... 39 02-23-2004 10:25 AM
Wheel lockup erstrong Brakes & Brake Controllers 2 10-07-2003 12:52 AM
need to replace the wheel...are there jacking points? 60traveler Towing, Tow Vehicles & Hitches 1 06-25-2003 03:05 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
