Old 12-12-2012, 01:59 PM   #1
susans69's Avatar
1976 Argosy 26
Lake Wales , Florida
Jack for Argosy
I would like to know what jack you use on your trailers? I am mainly concerned about how high it has to go. Any advice would be greatly appreciated as I need to have my brakes working by christmas.
susans69 is offline   Reply With Quote
Old 12-12-2012, 04:15 PM   #2
1988 32' Excella
Robbinsville , New Jersey
Well you could use one of these or blocks of wood instead of a jack.
Amazon.com: Camcoģ Trailer Aid Plus: Automotive
Doing this on both sides you could do 1 axle at a time, if you don't have much experience with breaks it sometimes helps to have a complete brake setup to look at when reassembling.
Old 12-12-2012, 09:35 PM   #3
susans69's Avatar
1976 Argosy 26
Cool idea and product. Thank you.
Old 12-13-2012, 10:54 AM   #4
1988 32' Excella
1 question are you planning to just change the shoes or the whole assembly?
Changing the assembly is easier and safer since you get rid of many rusty parts and get new magnets.
Several people have recommended the Nev-R-Adjust brakes, I haven't tried them though. Here is a link to them.
Trailer Brakes | etrailer.com
Old 12-13-2012, 04:38 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I put the self-adjusting brakes on our old trailer and was very happy with them. Would definitely use them again.
Back to the original question though, I carry a 6t hydraulic bottle jack. Along with a few blocks of wood it's plenty enough to lift the trailer. You should be carrying some blocks for leveling when camping and these also can be used to raise 1 wheel or one axel to service or change the wheel ( on a 2 axel trailer that is).
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-13-2012, 04:54 PM   #6
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I would never use a bottle jack on an AS IMHO. The "Trailer Aid" is much safer and you don't have to worry about the jack failing or trying to get it in the "exact" spot on the frame. Also, if you do have a flat, most times you can't get the bottle jack under the best location. If you must use a jack, a good sizzor jack is much safer and better, easier to handle and has a broader lift than a tiny bottle jack.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 12-13-2012, 07:25 PM   #7
susans69's Avatar
1976 Argosy 26
I think a bottle jack would work good to raise the trailer then put blocks to stablize.
Old 12-13-2012, 07:27 PM   #8
susans69's Avatar
1976 Argosy 26
It might be best to replace them as they are probably worn or will be soon. Good idea
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Electric Jack Not Working eberrobw Jacks, Stabilizers, Lifting and Leveling 13 03-13-2012 11:23 PM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
