Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 10-15-2009, 03:03 PM   #1
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
Is this a wheel cap? If so, where do I get one?
This one apparently got schmooshed by the PO. I've worn out a set of tires going from store to specialty store trying to find a new one. I have Alcoa wheels, and the other three wheels have lovely ones.
Any ideas on who would sell them?
The road to a friend's house is never long. (Old Danish Saying)
Old 10-15-2009, 03:33 PM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Greetings Aage!
If you have the bore measurement and the depth of cap needed, one of the following two on-line sources may have what you need. They both had the size that I needed for the new wheels that I purchased for my Overlander (the ones that came with the wheels weren't deep enough).
Trailer and Truck Parts
Trailer Tire and Wheel Supermarket
or possibly:
Out of Doors Mart
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 10-15-2009, 03:43 PM   #3
Airslide's Avatar
Profile:  2001 30' Limited
Novato , California
Images: 47
Send a message via Yahoo to Airslide
Thats a good lookin wheel cap.. why would you want to replace it? It might have went to Cairo?
2001 Airstream 30' S/O 70th Anniversary
1994 F-350 Crew 7.3 IDI Turbo, C6, Dually
Airslide is offline   Reply With Quote
Old 10-15-2009, 04:34 PM   #4
Profile:  1985 31' Excella
battle ground, , Washington
i'd try to straighten it out! even if you have to use heat and then shrink it! ya can't hurt it-may as well give 'er a bash or two-form a chunk of 2x4 wood to match the inside-put it on something that has a little "give" but is sturdy and won't move too much (like an anti-fatique floor mat) and whack the 2x4 til the dang thang starts looking like its former self. if the wood ain't stout enough to remove any "NEW" (dented) high crown areas then use a brass drift bar and bash away until it starts cooperating. If I were there, I'd gladly give you hand, but Ontario is a ways...
wmarsha is offline   Reply With Quote
Old 10-15-2009, 06:16 PM   #5
Kevin, I'll give those leads a shot, you never know.
Airslide, WMarsha, I showed the good side of the cap, now here's t'other side. Let me know if it looks good to straighten.
ps: it might have gone on the Mexico caravan, because Henri did do that one, but the dent looks suspiciously like the deck I pulled him away from last week...
Old 10-15-2009, 06:20 PM   #6
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
It appears that the wheel cap in not a good jacking point...
Richard
Charter Member Four Corners Unit
Old 10-15-2009, 07:24 PM   #7
Profile:  1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
I just went through this a couple of months ago on a 74 Ambassador. Had a TERRIBLE time! Spent every night for a week online with no luck. Called all over the United States, no luck. It appears that your cap is 3.75" very difficult to find this diameter (it's partial to Airstream). Finally found one at Camper Repair Center in Alabama. (205) 665-2531. Ask for Sonny and be prepared to open your pocketbook.
bimpy is offline   Reply With Quote
Old 10-15-2009, 07:39 PM   #8
Profile:  Grain Valley , Missouri
I keep saying to people, "Call Colaws RV salvage." However, as said before, hold on to your checkbook. Just Google Colaws Rv salvage. They have lots of Airstreams in all sizes and categories.
QuietWater is offline   Reply With Quote
Need wheel backspacing info and weight cap suggestion GoMopar440 Wheels 6 01-07-2009 05:11 PM
Sizes Dust cover cap, wheel bolts Lothlorian Wheels 5 06-19-2008 09:47 PM
Drip cap - Where's it at? 62overlander Windows & Screens 20 12-17-2007 08:19 PM
where to find wheel center cap tslanier Wheels 4 04-03-2007 07:11 PM
Argosy Hub Cap/Wheel Cover COArgosy78 Parts Archive 11 08-12-2004 10:33 AM
