Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 10-12-2008, 01:52 PM   #1
Profile:  1949 18' Trailwind
Huntsville , Alabama
Images: 11
Question Is this a split rim????
sorry to jump in here. can someone look at the pic below and confirm with me one way or another if these rims and in fact split rims? i see no outer ring. i want to be for certain before i get new tires for the rims. also i want to stick with the vintage baby moons that i have that are just waiting to get shined up. thx
Benjo is offline   Reply With Quote
Old 10-12-2008, 01:53 PM   #2
Images: 11
here's the pic
Old 10-12-2008, 02:36 PM   #3
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Picture is inadquate because it doesn't show all 360*. Look at the rim where it meets the tire. A split rim will have a gap somewhere in the circumference-hence split rim. No gap? Not a split rim.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 10-12-2008, 03:31 PM   #4
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
It is hard to tell fom the picture. This is what you are looking for.
Richard
Charter Member Four Corners Unit
Old 10-17-2008, 06:58 PM   #5
1972 Travelux Princess 25
Profile:  Cobourg , Ontario
Yours looks like a standard rim, not split rim, to me.
Split rims were used for heavy duty truck tires, with sidewalls so stiff it was impossible to pry them over the rims. They can only be used with inner tubes.
Would suggest you take your rims to a tire store and have them sandblasted and painted. They can also inspect for damage, and true up the rims in other words straighten them. This is money well spent for a smooth running rig.
Even though it will cost more than buying new modern rims it is worth it to keep the original appearance.
Ganaraska is offline   Reply With Quote
Old 10-17-2008, 07:09 PM   #6
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
1983 27' Excella
Walnut Grove , California
Standard rim for sure.
Old 04-13-2009, 08:27 PM   #7
Profile:  1959 26' Overlander
Seattle , Washington
How about these rims? Can anyone tell if these are split rims? This is the best pic I have now, but should have better tomorrow. I'm inclined to just replace them out of an abundance of caution as a friend of mine is about to tow this 1,200 miles for me.
Name:	Curb Side Wheels.jpg
nmbosa is offline   Reply With Quote
Old 04-13-2009, 08:42 PM   #8
Excella CM's Avatar
Venice , California
Look at the rim of the wheel where it is retaining the tire bead. If it has a break in it, it's a split rim (two piece wheel). If there is no gap, it's a regular wheel.
Old 04-14-2009, 08:28 PM   #9
The first pic looks like a standard 1 piece wheel. These will last indefinitely if not bent in an accident, or rusted through.
Tire stores can true these wheels up, beadblast and paint them and they are good as new.
Azflycaster shows a split rim. Notice how the rim comes apart in 2 pieces. It is held together by a ring made of steel rod bent in a circle.
These were invented so as to make it easier to install very stiff 8 ply truck tires with no fancy machinery. They work well on farm and construction equipment.As long as they don't fly apart. They cannot be used tubeless, they must have an inner tube. Tubes do not disperse heat as well as tubeless tires which means more chance of a blowout or tire failure.Most people replace them with more modern wheels.
Once you know the difference you can look at a rim and see instantly if it comes apart or is made in 1 piece.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Old 04-14-2009, 10:34 PM   #10
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
They are one piece wheels, but they look "off". Do you know what diameter and width they are?
(No Longer at Inland RV)
Old 04-15-2009, 03:57 AM   #11
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Several points to remember when dealing with split rims..
1.NEVER, deflate the tire without the tire "FIRST" being enclosed in a safety cage~!!
Fact~it been known that these split rims can and do fly off, causing deadly injuries~
2.Forget this original looking "theory", this is one case where SAFETY comes first~
Fact~while they are not totally outlawed, you are not gonna find very many places that are willing to deal with them because of the safety concerns.
3. That picture showing the rims being pried off chills my blood..That is precisely how you should never do it~!
You had to have had "angels" watching over you that day..
Safety is the first considereation~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-15-2009, 05:07 AM   #12
danalee's Avatar
Profile:  1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
We have split rims and they required a tube with an extra long stem.
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 04-16-2009, 03:42 PM   #13
It's inflating, not deflating, that is dangerous. Once the rim is properly seated it cannot be taken apart until fully deflated.
Putting them back together is when the fun starts. If the parts do not go together properly the rim can fly apart like a bomb when the air pressure gets high enough. This is when you need a cage or at least a chain wrapped around the tire and bolted together.
Old 04-16-2009, 04:10 PM   #14
Terry, they were 14.5 x ? with 14.5 7 MH tires. I just replaced them with 15 x 6 Dexstars and 225 75 15 tires. Unfortunately, one of the new tires was rubbing against what appeared to be a replacement shock mount and we had to remove the shocks. I may yet have to move down to a 205 75 15 before the long journey up I-5 starts.
Is this an Airstream hubcap? Split rim? Zstream Wheels 6 05-02-2008 09:56 PM
Split-Rim Replacement for 1964 Overland judas Wheels 7 05-17-2007 12:37 PM
Split rim replacement CaptainJones Wheels 4 02-07-2007 07:26 AM
What does a split rim look like? tbrom Wheels 9 09-30-2006 04:58 PM
Split Rim Or Not? Jabba Wheels 3 11-11-2002 07:43 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
