Old 08-19-2011, 10:12 AM   #1
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Is this a good replacement wheel?
Is this trailer wheel offered on eBay an appropriate replacement for the old original wheels on our '66 Safari -- single axle?
Aluminum Trailer Wheel 15 x 6 12 Hole Mod 6 on 5.5 | eBay
Old 08-19-2011, 10:34 AM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
You may want to check your lug pattern on your trailer. The original axle was 5 lug on 5" center or 5on5 when you ask for one at the trailer supply store. This is a 6 lug rim in the auction.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-19-2011, 10:42 AM   #3
That wheel should be OK.
It has the proper bolt pattern, 6 on 5 1/2 as well as the proper weight rating.
6 on 5 1/2 and 5 on 4 1/2 are USA standard lug patterns.
Old 08-19-2011, 10:49 AM   #4
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I have a 63 Safari and it uses 6 lug wheels with 12" brakes!
The wheels look good and have a good weight rating! IMHO
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 08-19-2011, 11:06 AM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You should verify that the offset is zero. I do not see any mention of it in the ad.
Richard
Old 08-19-2011, 01:38 PM   #6
1966 22' Safari
Weatherford , Texas
Thanks everyone! I'll check the offset before I buy anything.
Old 09-02-2011, 04:46 AM   #7
Rivet Master In Training
Kevo's Avatar
1965 22' Safari
Mount Airy , Georgia
Send a message via AIM to Kevo Send a message via MSN to Kevo Send a message via Yahoo to Kevo
You can get the new ones here w/caps and lugs....
Aluminum Trailer Wheel Style: SERIES #03 Size: 15 x 6 Bolt Pattern: 6 x 5.5 Bore Size: 4.25 Load Rating: 2830 lbs @ 80 PSI Offset: 0mm Hispec
Kevo is offline   Reply With Quote
Old 09-02-2011, 06:42 AM   #8
1972 27' Overlander
Saline , Michigan
Ditto,
At fellow member UWE's advice I put 4 of these rims on my 1972 27' International in 2006, they have performed very well, I have taken them on multiple cross country trips.
Look here: www.trailertiresandwheels.net
http://www.trailertiresandwheels.net...product/AW1504
Steve
loechli is offline   Reply With Quote
Old 09-02-2011, 07:27 AM   #9
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I put those same rims on my 65 Safari 1.5 years ago. No problems and they look great.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Panel Replacement Bert Gildart Ribs, Skins & Rivets 3 08-02-2011 10:55 PM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
