Old 05-30-2015, 05:14 PM   #1
Lynn
Beaverton , Oregon
Installing TPMS sensors
Wanting to install a TPMS system on my 25 ft Safari. I currently have 45 degree valve stem extenders installed. Would like to use the flow-thru sensors. Can the sensors be installed on the extenders or should they be removed? Any advise would be appreciated.
Lynn
aliner is offline   Reply With Quote
Old 05-30-2015, 06:26 PM   #2
2016 30' Classic
Erie , Colorado
You should replace the current valve stems and the extenders with all metal valve stems. Whey you get it done have the tire place spin balance the tires with the sensors in place.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 06-05-2015, 09:59 AM   #3
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Tpms
I had a set of TPMS's they stressed me out never worked I was getting low warning signals stop check pressure and it would be ok sent them back to camping world for refund. Now I just check pressure each morning of travel and do walk around at all stops fuel restroom breaks. Good camping Rand
grizbear is offline   Reply With Quote
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Dill TPMS PJohnson Tires 20 05-15-2014 12:02 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Thoughts on TPMS mwells4654 Tires 33 11-02-2010 04:20 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
