Old 01-01-2013, 04:47 AM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Installing New Races in Hubs - Help Needed
Happy New Year Everyone
My winter project is new wheel bearings. I have purchased new races and bearings.
I had a hard time driving out the bearing races from the brake drum, or some say hub. I used a punch and hammer. There was very little of the bearing race exposed to rest my punch and bang out the race. But I finally got them all out.
I now have to drive the new races into the clean hub. I don't have a press or proper bearing driver. What have you folks devised to get the race started in its bore, and then drive it to the shoulder?
My brake drums are Dexter 12 x 2 with six studs rated at 5200. I see they sell them new with the bearing races already installed.
David
Old 01-01-2013, 04:56 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I have used the old bearing race or a board, as a buffer, and driven them in by tapping evenly with a hammer. If it cocks, it will not go. If you warm the drum and freeze the race it will be easier.
Old 01-01-2013, 06:59 AM   #3
1977 Argosy 24
Milltown , Wisconsin
Find a socket that is just a little smaller then the race to use as a driver.
ventport is offline   Reply With Quote
Old 01-01-2013, 07:34 AM   #4
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Yes,
... good advice above. There's almost always a socket that's just the right size. And heating the hub in the oven and chilling the race in the freezer often gives "just enough" interference fit differential to make the job easier. Also, make sure that the hub's machined surface where the race fits is completely clean - a little extra time spent here with some very fine emery cloth or such can pay big dividends.
AirsDream is offline   Reply With Quote
Old 01-01-2013, 07:42 AM   #5
SteveH's Avatar
Common Sense , Texas
I like to use one of the old races as a buffer between the hammer and the new race, but I cut a slot in it with a power hacksaw so it will compress just a little. It works well, allows you to drive the new race all the way in, protects the new race, and makes the job easier.
Been doing this for years, and now have a complete set of races for every trailer I own, but wouldn't you know it, our new to us '10 uses Neverlube bearings, so now I need to buy a large socket and C clip pliars.
Regards,
Steve
Old 01-01-2013, 08:00 AM   #6
2003 25' Safari
Riverside , California
That's the same technique I use when I do an install that I don't have a driver for but I use a cut off saw on the old race
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 01-01-2013, 08:02 AM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I like the idea of cutting a slot in the old race to use as a driver. I will look for two big sockets with the right outside diameter to use as a driver.
And I like the idea of freezing the race, and maybe heating the hub to reduce the interference fit. These ideas give me hope I can drive the new races to the shoulders with out damaging them.
Heck, here in Minnesota, the great outdoors is just one big deep freezer. It will work great to leave my races outside overnight.
David
Old 01-01-2013, 08:27 AM   #8
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Take your time and go lightly " all around" no matter what method you choose. They will go in. Patience is your friend here. As you tap them in you will hear the difference in the sound when they hit bottom. You'll know when you're there.
Good luck with it. And HAPPY NEW YEAR
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-01-2013, 09:06 AM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Socket as a driver, done that, works just fine. I have one possible try this about using a socket. Make a mini press out of a piece of 1/2" or larger diameter threaded rod. This requires a large enough set of washers to bridge across the 1/2" or 3/4" drive hole in the socket and a piece of steel on the opposite end to pull against. Set it up and start tightening, watch for any tilting, and reset, start tightening, continue until seated. I think you'd be surprised how controlled this is and doesn't impact the parts, just pulls them in.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 01-01-2013, 09:14 AM   #10
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
All good suggestions above. But I was happiest when I bought a graduated set of drivers with beveled shoulders to match the race . Just remember to go slow and tap, tap, tap. Don't bang, bang, bang.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 01-01-2013, 09:37 AM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
That is a great idea. Use a threaded rod as a "press". I'm going to rig up something along those lines. I recall my strut spring compressor I used to compress the springs on my car. Worked just fine.
David
Old 01-01-2013, 10:22 AM   #12
1972 Travelux Princess 25
Cobourg , Ontario
I find the hub more stable and easier to work on if I leave it bolted to the wheel. This does not apply if you have a fully equipped work shop with giant press.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 01-01-2013, 10:27 AM   #13
Central , Mississippi
I haven't done this on an airstream hub but I have on other applications...
To install the new race, heat the hub in a hot plate. Cool the race in the freezer. One quick move and the race will drop right into place, a couple of taps and its set!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-01-2013, 10:52 AM   #14
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2....races drop/tapped right in when I did our 63 Safari. Put races in the freezer overnight and carefully heated the hub's. (did have O/A torch though), give it a try with a propane unit, can't hurt, beat's bang'n.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
