Old 04-11-2009, 05:58 PM   #15
bertro's Avatar
1971 23' Safari
Groveport , Ohio
That could be the difference. I believe my full wheel covers that it came with were orig. to it as it was an Ohio build. I wish I could figure out a way to keep from loseing one. I thought about thin ga. stainless wire around the wheel clips to the cover in three spots. But I'll take my chances. Thanks for the reply. Robert
bertro is offline   Reply With Quote
Old 04-11-2009, 06:18 PM   #16
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by bertro View Post
Was there an option for full covers or baby moons in 71 as I have seen both and owners say they are original. Robert
What do the "full covers" you speak of look like?
Old 04-11-2009, 06:33 PM   #17
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Sorry mabey I wasen't clear as to what I had. Just run of the mill caps. Robert
Old 04-12-2009, 06:14 AM   #18
1972 Travelux Princess 25
Cobourg , Ontario
If you want to be absolutely guaranteed to not lose hubcaps here is how to do it.
Drill a small hole thru the edge of the cap into the wheel rim and put in a stainless steel screw. Do this at 2 or 3 spots around the wheel. I guarantee the hubcap will stay on.
This does not harm the wheel or tire in any way. For many years this was the only way to install "moon disc" hubcaps and they used them on 200 MPH race cars.
You will want to mark the hubcap so you can put it back on the same wheel in the same position or the screw holes will not line up.
Carry a screwdriver in your too kit in case you need to change a tire.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 04-12-2009, 04:41 PM   #19
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Into the rim? The same part of the rim that holds the air in? How does this work?
>>>>>>>>>Action
Old 04-12-2009, 06:45 PM   #20
Cobourg , Ontario
>>>>>>>>>Action
Like I said, they do it on 200 MPH race cars.
The screw should be just long enough to go thru the steel rim. It will not hurt the tire or leak if it sticks into the rubber.
Put in 2 or 3 screws. Use stainless ones, they will match the chrome and will not rust.
Keep a screwdriver in your tool kit in case you need to change a tire.
Old 04-20-2009, 08:10 AM   #21
Lothlorian's Avatar
Loganville , Georgia
I am very tempted to try this but I would like to know what size screws you would recommend? I am sure this problem has shown up with orginal hubcaps for classic cars.
Lothlorian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 04-21-2009, 07:26 AM   #22
Cobourg , Ontario
#8, 3/4" long self tapping screws.
Old 03-22-2010, 01:38 PM   #23
1985 25' Sovereign
Folsom , California
Bertro-- suggestion on where to buy these?
I haven't seen full covers like these that would fit mine..any idea where something similar can be ordered???
ridelikewind is offline   Reply With Quote
Original Hubcap? LHall Wheels, Hubs & Bearings 2 10-23-2007 06:18 PM
73 soverign hubcap Jalina Tires 10 10-12-2004 06:32 AM
Hubcap mmeburges1 Wheels, Hubs & Bearings 5 01-10-2004 08:26 PM
Hubcap benbailey Airstream Motorhome Forums 0 12-14-2002 02:48 PM
