Old 07-14-2013, 03:25 PM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Unhappy Hub Temps
Hi,
Finished a 200 miles stretch today with our '59 Tradewind. Got out and smelled burning. Shot the hubs and tires with my digital temp gun. got 114 and 116 on the left tire and hub. Then 116 on the right tire and 190 on the hub. Grease cap and hub was very hot to the touch.
Just repacked the bearings before this trip.
Original axle.
Any tips on what to look for when I pop the rim and brake drum off tomorrow?
Thoughts?
steveirving is offline   Reply With Quote
Old 07-14-2013, 03:31 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Maybe you cranked down on the castle nut too much.
Old 07-14-2013, 03:46 PM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Did you shoot the drum temps also?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-14-2013, 04:52 PM   #4
NoMoSOBs's Avatar
1998 30' Excella 1000
Aylett , Virginia
Images: 14
+1 what he said.
John T.
TAC VA-16
NoMoSOBs is offline   Reply With Quote
Old 07-14-2013, 06:16 PM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I'M thinkin' that you you did what the previous posters have said. I'm sure that you have the castle nut too tight. Back off the nut TWO flats and reinstall the cotter pin. You only have to take the cap off to do this. run it down the road about 5 miles and re-check temp. If it is going to be hot it will get there by then.
Now, if it was my trailer, I would disassemble the hub and check the bearings for any signs of "bluing" which would indicate they have been exposed to excessive temps. This will lead to premature bearing failure at the most inopportune time. Better to do it now in a controlled enviroment instead of on the road in the middle of nowhere.
Do not despair, we have all done this at LEAST once.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-20-2013, 01:50 PM   #6
GCinSC2's Avatar
Steveirving,
Any conclusion or findings? FWIW I just checked a container of Valvoline hi temp grease and it listed operating temp to 375F. You also mentioned a burning smell. Brake material has a pretty distinct nasty smell when it overheats.
Gary
S/OS #001
Old 07-21-2013, 06:50 AM   #7
1959 24' Tradewind
Quantico , Virginia
Images: 11
Originally Posted by GCinSC2 View Post
Steveirving,
Gary
Hi guys, since all your tips i took the hub apart and inspected everything. Plenty of grease still, no bluing or any sign of wear on bearings or races. All looked perfect. Lots of brake dust. Lots. I suspect the shoes were a little too tight. Backed them off and will road temp for temps today.
Old 07-21-2013, 06:40 PM   #8
1959 24' Tradewind
Quantico , Virginia
Images: 11
Hi all,
Roadtested the trailer on the highway today for about 5 miles. Pulled over and took temp readings:
Left side: tire: 114, hub: 118, drum: 125
Right side: tire 113, hub: 150, drum 250
I've inspected the right bearings, repacked in grease, and was very careful to tight the castle nut until hand tight, then back one pin hole. I also tightened the brakes, then backed off the pads until the wheel spun free, then 2-3 more turns off.
No evidence of metal bluing of burning on the spindle or bearings or races. No deformities that I can find.
What gives?
Old 07-21-2013, 07:06 PM   #9
1977 Argosy 24
Milltown , Wisconsin
Is there a groove in the backing plate that the shoes can catch on? It sounds to me like the shoes are not retracting completely. Are the return springs all there and on correctly? Remove drum and grab the magnet and move it in the correct direction the drum would go and see if the shoes move freely and retract correctly.
ventport is offline   Reply With Quote
Old 07-22-2013, 06:19 AM   #10
GCinSC2's Avatar
Steve,
Not sure what gives, my brakes are hydraulic. Sounds like shoe drag from an undefined source. Others can advise better on electric brakes, that backing plate suggestion looking for a groove that the shoe can get stuck it, good idea.
But what you have pretty clearly pointed out is the value of a point and shoot thermometor to troubleshooting. I carry one. Its also really helpful at other automotive diagnostics, heating, cooling and you can even shoot your trailer connection plug looking for heat.
Good luck,
Gary
S/OS #001
Old 07-22-2013, 06:53 AM   #11
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Who did the brakes? There are front and rear ones. If they are backwards they drag. Why didn't you replace the axel? Is 59 a leaf spring unit?
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
