Old 11-12-2011, 04:18 PM   #1
Landmammal's Avatar
1977 Argosy 24
Underalog , Illinois
Angry Hub "cap" and bearing seal missing
While on our last trip out with the 'Stream, we noticed an issue with one of our hubs. It was missing something. We finally narrowed it down to the bearing seal and hub cover. Someone had stolen them while it was in the gated storage lot.
This is for the trailer tires on a 77 argosy 24ft. You can see the difference between the two tires side by side. And you can see a close up of what is missing in the other shot.
Could anyone tell me the best place to purchase these and what exactly should I be looking for?
Landmammal
TAC IL-12
Air# 48404
Landmammal is offline   Reply With Quote
Old 11-12-2011, 04:42 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There is no seal for the outside bearing, just the dust cover.
Richard
Old 11-12-2011, 04:44 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Any trailer supply sales and probably most auto parts locations will have the bearing dust cap that you will need. Take another one with you for size. Should only be $3-$4 at the most.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-12-2011, 06:28 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Not all dust caps are made equal - the new Inland supplied axles come with sturdy dust caps that resist denting and are made to last for years - the local trailer/hitch store covers are little better than foil thickness, the first time installing them they dented and deformed terribly on just a little force.
Take a long look inside - is there evidence of contamination? grit or water? Its cheap insurance to remove and wipe everything down and repack is anything looks fishy.
I can't guarantee parts ala-carte anywhere are better than any other, just noting you don't have to settle for the cheapest thing made. If you don't like the one you get to get back on the road safely keep looking
Old 11-12-2011, 06:54 PM   #5
Kevin245's Avatar
Yes it is a dust cover and as Wabbiteer indicates, they vary in size and quality. You can mic the hubs but the best bet is to take one of the others off and carry it with you to the store.
We keep a couple of spares in the toolbox along with a spare set of bearings and some grease seals.
Eleanor Roosevelt
Wheel bearing & seal specs for 2005 Classic 30' Wingeezer 2001 - 2005 Classic 3 12-12-2016 12:47 PM
Bearing grease seals Sailor-d Wheels, Hubs & Bearings 7 08-16-2012 12:43 PM
Bearing, Lug, tire for 1956 soldiermedic Wheels, Hubs & Bearings 5 06-14-2011 01:36 PM
Hot Hub /Wheel - Help diagnose Please Sav'h Steve Brakes & Brake Controllers 27 04-21-2011 08:39 PM
Does NADA have any bearing on reality? International 23D smeghead Trailer Values 20 04-13-2011 01:18 AM
