Old 11-03-2012, 07:44 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Hub Bolts to Nuts?
Just purchased a "74" Tradewind that has bolts that screw through wheels into the hubs. I would like to change the hubs so that there are bolts mounted to the hubs allowing the wheels to slide over the bolts and then attach with lug nuts. What do I need to do to accomplish this? Do I need to buy new hubs? Thanks for the help!
PA TAC-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 11-03-2012, 08:32 PM   #2
rogerdodger's Avatar
Fresno/Clovis , California
It's almost as expensive to replace the bolts, as it is to replace the drums with bolts included. Before you make that decision, make sure you have good axles, you can get new axles, brakes, drums, as a unit.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
