Old 08-16-2010, 09:53 AM   #1
sierrajb's Avatar
Arlington , Texas
How to remove, repack, and replace bearing?
Great info on this thread! Thanks so much.
However, I'm looking for the thread that gives a very detailed explanation of how to remove, repack, and replace all the bearings and seals. I believe that thread was complete with pics. I'll keep looking.
Can I purchase new bearings & seals from somewhere around the Dallas-Fort Worth area, or will I need to wait on the parts guru in California again? Any insight?
Airstreams are like a box of chocolates....
sierrajb is offline   Reply With Quote
Old 08-16-2010, 10:05 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Moved from a different thread. He is looking for support.
>>>>>>>Action
Old 08-16-2010, 10:07 AM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The bearings and seals on ours are common and easy to get in an auto parts store. The problem is knowing what the numbers are. You can call Airstream, look on their website, or call a dealer to find out. When I had a bearing failure on the road, the nearest parts store had no idea how to find out the right numbers, so that's when I called Airstream. Once I got the right numbers, I had the parts the next morning.
Gene
Old 08-16-2010, 11:27 AM   #4
sierrajb's Avatar
Arlington , Texas
Thanks, Gene. I'm guessing Airstream would have the exact numbers for my 75 Argo, even if it's 35 years old...right?
Old 08-16-2010, 11:51 AM   #5
Master of Universe
Gene's Avatar
Maybe. If you call the service center, you may have to leave a message as the phone is always busy. Customer service is easier to get through to, but they may not have the information. You can send an e-mail to them. Also check the website.
But, if the running gear has been changed in the past 35 years, the specs may be different. A slightly different hub can require different bearings and seals. Newer axles may have come with different specs. Then you will have to do some more investigating to match bearings and seals.
Gene
Old 08-16-2010, 12:37 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
My old bearings and seals were Timken brand and had the numbers right on the side in easy to read print. Auto parts store had exact OEM bearings and seals right on the shelf.
Old 08-16-2010, 01:28 PM   #7
Master of Universe
Gene's Avatar
That's much too easy.
Gene
Old 08-16-2010, 02:22 PM   #8
sierrajb's Avatar
Arlington , Texas
Waiting on Airstream Callback
Gene
Gene, I followed your lead. My local AS dealer wasn't much help on my older model. Said I needed to bring it in for $500. HA! Next, I called Airstream in Ohio 937-596-6111 to ask for correct numbers. Waiting to hear back from them.
Another post mentioned the possibility of these bearings being different from original if I've ever had the axles replaced. Well, I have the original axles (which, contrary to popular belief) are STILL in good shape and show no signs of stiffening. So, I'm expecting AS numbers to match without any problems.
Thanks!
Old 08-16-2010, 02:25 PM   #9
sierrajb's Avatar
Arlington , Texas
Timken?
I was hoping to have replacements lined up BEFORE taking them off just in case it would leave my trailer inoperable too long. The AS dealer here said I would need to take off my seals and bearings, take them to NAPA for sizing, then hope they had them in stock. If not, the Argo would remain on the stands. Yuck!
I think the only way I can be sure Timkens will work is if I have an AS number(s) I can cross reference. Still waiting to hear from AS. Thanks!
Old 08-16-2010, 03:35 PM   #10
Some Argosy trailer records, are not very clear.
For the 10 inch Argosy trailer brakes, the bearings are L68149 and L44649.
The grease seal number is 58846.
Old 08-16-2010, 04:07 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Take one set off, go to NAPA or Carquest. If they don't have them in stock, most stores can get them the next day. Be sure to take both inner and outer races on both outside and inside bearings as well as the seal. Are you sure the ones you have are bad? Perhaps you can just repack them, but you will need a new seal for each one, no matter what.
Old 08-16-2010, 04:20 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Type " How to repack wheel bearings" into Google. There are many videos and much info on this subject.
Old 08-16-2010, 04:22 PM   #13
sierrajb's Avatar
Arlington , Texas
Andy, thanks for those numbers. Can I take those to a local automotive shop and expect them to cross reference them? I've never had the drums off to check the size of brake shoes, but I'll inspect those, too, when I repack the bearings. I'm guessing Inland has everything I need if I can't find them (seals, bearings, etc.) at a local store, right?
Twinkie, I don't think any of my bearings are "bad", but I'm trying to prepare for what I might discover when I disassemble them. I will definitely replace the seals after cleaning and repacking. Thanks for chiming in with the rest who have come to my rescue!
Old 08-16-2010, 04:23 PM   #14
sierrajb's Avatar
Arlington , Texas
Mind Reader!
Wow! You must have read my mind, Twinkie! I just watched a couple on You Tube, but it made me wonder if my Argo setup was much different. Probably not. Thanks so much!
How to remove old wheel bearing grease? hiker Wheels, Hubs & Bearings 36 08-04-2010 01:26 AM
Repack wheel bearings; OR, Bearing Buddies??? macsfriended Wheels, Hubs & Bearings 18 04-03-2008 12:14 PM
1st Bearing Repack, new tires.... SafariSS Winterizing, Storage, Carports & Covers 2 11-10-2007 07:31 PM
replace bearing? michaelsessa Axles 5 04-27-2007 12:54 PM
Wheel Bearing Repack? JaceBeck Axles 24 03-15-2004 07:38 PM
