04-05-2010, 09:37 AM
#21
1992 34' Excella
Austin
Diesel fuel works fine and it's much safer as a solvent/parts cleaner than gasoline is.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
04-05-2010, 09:59 AM
#22
1980 31' Excella II
Drummond Island
, Michigan
Ohh, how I hate wheel bearing grease on my hands especially some of the synthetics or wateproof types with dye in them. Wear nitrile gloves when handling the bearings and a little trick I was taught by an old time mechanic years ago. Put the bearings in a plastic sandwich bag, throw in a blob of bearing grease, close the bag and put the bearing in the bag into the center of your palm and massage the new grease into the bearing with your other hand. It's a whole lot less messy that way.
04-05-2010, 10:05 AM
#23
2015 27' Flying Cloud
Portland
, Oregon
My 2 cents. Based on over 30 years as a firefighter and the owner of a foreign car repair business, NEVER use gasoline as a cleaner. If you are a repair facility, you would be in violation of the fire code and required to stop immediately. Not only are the fumes toxic, but I can't tell how many buildings and even apartment complexes caught fire from someone using gasoline to clean car parts. Where do home mechanics work on their vehicles? : the garage. Where is the natural gas fired water heater and furnace usually located?: the garage. I even provided medical care to idiots burned from washing vehicle parts in a shallow pan while smoking a cigarette. Any reputable repair facility uses solvent. It is less toxic and far less volatile. Kerosene or diesel fuel is a second choice. My favorite cleaner is a liquid that comes in a 1 gallon metal container called Tyme. It was by far the best at cleaning carbon deposits in carburators and goes after dirt and grease like Sherman went through Georgia. Also rinsed off with plain old water. Very hard to find though. The problem with any of these methods is what to do with the used stuff. I think most states require it goes to a hazardous materials facility. In larger communities, there are free drop off sites. Most counties have them too. Some repair shops will take it for a fee, but most avoid mixing unknowns with their solvents.
04-05-2010, 10:12 AM
#24
2019 28' International
Leonardtown
, Maryland
Any solvent used that is flamable, should be used in a plastic container and do not use an acid brush with a metal handle. All solvents need to be disposed of in a proper manner. We have a recycling center at the transfer station.
My favorite bearing greese is Wolfs Head.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
04-06-2010, 07:32 AM
#25
2007 25' International CCD FB
Rochester
, New York
Originally Posted by markdoane
Why don't you wipe off as much as you can. Then clean them with solvent and see how much old grease and crud you missed?
thanks to everyone for your advice. As yet, no-one who has replied just wipes away the old grease with a shop towel; everyone uses some type of solvent. So unless I hear otherwise, I'll use the method suggested above.
again, thanks for your help
Mike & Joan
WBCCI #1521 New England Unit
06 Chevy Duramax/Allison
04-06-2010, 08:58 AM
#26
Kmpro
1984 31' Airstream310
Lubbock
How to remove old wheel bearing grease
After reading all this thread Let me share from 35 years experience with wheel bearings,
1.Use clean shop towel to remove excess of grease from bearings and races
2. Use approved safety solvent to wash bearings and races to remove all traces of grease
Note: Do not use Gasoline! The safety factor alone should stop you, it is HIGHLY flammable and Dangerous.
3. Wash bearings and races with Hot soapy water and rinse in hot water.
4. Blow bearings and races dry with compressed air Danger: Do not spin bearings with compressed air as they can sieze and explode.
5.Wipe clean with clean lint free shop towel and carefully inspect bearing rollers and races for wear. Keep bearings in matched sets always.
6.Repack with approved bearing grease (Drum brakes usually call for a different grease than Disc Brakes) using the heel of your hand working grease completely through bearing. If available a good bearing packer is suitable also. Coat Races with a coat of lubricant when re-installing. Be sure to replace wheel seals and coat them with a thin layer of lube.
7. When re-installing roll wheel as you tighten bearing nut to about 4-7 lbs ft of torque, note position of nut, back off one flat(1/6 turn) this should give you approximately 3-5 thousanths end play which is preferred for roller bearings that are externally packed.
I cannot overemphasize enough DO NOT USE GASOLINE to clean bearings!!! One spark and you are a serious burn victim, and yet I see articles in the paper from time to time about this very thing... Remember SAFETY FIRST!!!
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
04-06-2010, 09:03 AM
#27
1976 31' Sovereign
ozark
, Missouri
Let the pros do it
We have a shop here in Mo. that charges 20 buck a side to repack the bearings.
If they need a new boot/boots then your lookin at around 75 bucks. Worth it to us.
04-06-2010, 09:14 AM
#28
Kmpro
Lubbock
Pros sometimes short cut, $20 per side sounds like "Too cheap" to do the job right.
Mike
04-06-2010, 10:39 AM
#29
Master of Universe
2008 25' Safari FB SE
Grand Junction
Sometimes in small towns I have found a shop that charged next to nothing for very good work. That doesn't mean that shop in Mo. is good or bad, but the price doesn't always tell the entire story. I have also experienced shops that charged market or above that did crap work.
Agree that a solvent is part of the solution to cleaning. Blow dry from the side of the rollers and they won't spin much, though I agree with Wayne&Sam it is fun to watch them spin. Even with a solvent, a little bit of grease remains and does lube the rollers slightly if they spin. Gasoline is dangerous, but I continue to use it in my truck and have transported it across country many times. There are plenty of effective solvents available that are much safer. I have blown out grease before wiping it off and that gets rid of a lot of it right away. Any doubts about bearings or races means they should be replaced—they are cheap.
I've had a bearing fail on the road and it's no fun. We were 1/2 mile from our destination and the CG didn't complain about fixing the problem there. Many CG's have rules about fixing anything. Since we have 2 axles, we could limp into the CG. Finding the right numbers for bearings, etc., was a chore and I spent well over an hour on that, taking things apart and cleaning up the scene of the crime, going 45 miles each way to town for parts, then putting it all back together, wasted about a day. Later we found the hub had been damaged (although the brakes worked and the wheel did fine for thousands of miles after I fixed it), and that cost a lot more. A race that I had a shop press in after the bearing failed was spinning in the hub—another "pro" job. It all started after I repacked the bearings and a "pro" at a garage told me the castellated nut was too loose and he tightened it, apparently much too much. It took 3,000 miles for it to fail and I found out just before the wheel would have started rolling down the road on its own. I'd rather not repack my own bearings, but considering that a lot of shops do a bad job—and there are plenty of threads about bad wheel bearing and other work—and the cost of having it done, I'd rather do it myself.
Gene
04-06-2010, 10:42 AM
#30
Rochester
, New York
Thanks for your detailed post.
I assume the reason for washing with hot soapy water then rinsing and drying is to remove trace residues of solvent.
Do you have any experience with skipping this step?
Mike & Joan
04-06-2010, 10:46 AM
#31
Kmpro
Lubbock
Yes, if you wash with water and blow dry, this allows the grease to adhere to the bearings since they have no residue of oil left on them.
Mike
04-07-2010, 06:28 PM
#32
Moderator dude
1966 26' Overlander
Phoenix
I have cleaned bearings with out the soap and water cleaning step. However soap and water is a great insurance step to making sure all of the old grease is gone. Just make sure you get the water out swiftly so the metal does not rust. This is where using compressed air sprayed at the side of the bearing can remove the water swiftly.
Other issues -
In addition to the safety thing, gasoline will leave a residue when it has dried.
Wheel bearings were not made to spin at the speeds compressed air can move a bearing. In addition, spinning bearing in that manner means the bearing almost zero lube spinning at speeds it was not designed for. True the load is low.
>>>>>>>>>Action
04-07-2010, 07:15 PM
#33
tallahassee
NO - Don't use solvent!
You asked for it - so here is a method where you don't use solvent of any kind. Get yourself a wheel bearing packer and some basic black moly grease. You expel the old grease and at the same time you are forcing in the new. This is much much simpler than the older methods and you don't have the problem of waste disposal.
Carol
Toolmonger » Blog Archive » Pack Your Bearings Before You Pack Your Bags
04-07-2010, 08:04 PM
#34
If you do a final rinse with alcohol you will remove any residue of old grease, kerosene, mineral spirits, or soap and water.
And you can let the bearings air dry without using compressed air.
04-07-2010, 08:48 PM
#35
1982 28' Airstream 280
Anchorage
, Alaska
kerosene
Hi,
Brush with kerosene and use low pressure air to blow it out
ram64gq
04-08-2010, 10:39 PM
#36
Kmpro
Lubbock
Let me stress this again. Approved safety solvent to wash out old grease, followed by wash in hot soapy water to remove oily residue, rinsed in hot water, and bearing blown dry with compressed air. DO NOT SPIN BEARING WITH COMPRESSED AIR!!! Then wipe with a lint-free shop towel and inspect bearing races and rollers for damage or pitting. Keep bearings matched with races. This is an ASE approved method of cleaning bearings. Alcohol, laquer thinner, mineral spirits, and other distillates are either too dangerous, or can cause other problems to occur. Safety solvent is not cheap, but blowing up your house or garage or burning it down is not recommended either. In serving as a consultant to the automotive industry since 1968, I have heard many horror stories of fires and explosions caused by using Gasoline, Kerosene, Alcohol, Paint Thinner, and Laquer thinner to clean wheel bearings. To avoid great danger, use the proper safety solvent for washing bearings and parts when you are the DIY tech, practice safety.
Mike
08-04-2010, 01:26 AM
#37
1970 27' Overlander
Sumner
KMPRO you said it right, this is 'the' way people.......
I also don't hear anybody saying to look for discolored bearings or races, the color change usually means overheating, even if they look good, if they lose their temper due to overheating, they will disintegrate.
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
