Old 06-16-2010, 01:17 PM   #1
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
How to remove hubcaps
Potentially silly question here:
How do I remove the hubcaps? I need to bring one of my tires up to rated inflation, and the airpump won't fit on the valve stem because it's not sticking out enough.
Crowbar? Screwdriver? Pointy stick?
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
Old 06-16-2010, 03:20 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I think it's a good question.
In days of old, every tire shop had many of these laying around:
The design kept the technician from scratching the wheel. If you don't mind an overseas order, you too can have that tool for £8.99.
I bought valve stem extenders for my Overlander from the local auto parts store. Below is a picture of the extender, and the tool I use when the hubcap needs to come off for any other reason.
Tom
Old 06-18-2010, 02:45 AM   #3
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I carry a long screwdriver. Works just fine. My wheel covers were very difficult to remove because they fit so good.
Also, I bought valve extenders from Myers tire equipment supply. They are metal, made in switzerland or austria and work great. Much higher quality than the plastic extenders which I don't trust.
wingfoot321 is offline   Reply With Quote
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
have you used these hubcaps? gparker Wheels, Hubs & Bearings 3 11-02-2006 08:26 AM
Hubcaps Eric Wheels, Hubs & Bearings 2 10-21-2002 04:17 PM
