Old 01-10-2011, 07:47 PM   #1
new braunfels , Texas
How to remove baby moon hubcaps?
I got baby moons, but they fit tight over the clips- what is the trick to removing them without damaging them?
poezlaw is offline   Reply With Quote
Old 01-10-2011, 07:55 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have them on my TW. I just use a really large flat blade screwdriver. Carefully twist rather than just prying while working my way around the hub cap. If you can't get the tip in between you might try using one of those hard plastic wedges that you can by at a hardware store for leveling toilets. Tap the plastic wedge in with a non marring hammer and then use the screwdriver or other flat piece of steel to work the caps off. Be very careful when you put them back on. If the clips are rusty and real tight, you can dent the cap when you bump it back on with your hand (how do I know this?)
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-10-2011, 08:06 PM   #3
miker64867's Avatar
1987 32' Excella
1978 29' Ambassador
1971 23' Safari
Ball Ground , Georgia
Google search, Hyde Tools paint can opener. I use one on a 1948 Dodge Coupe to get the moon caps off. Works great, doesn't damage the painted wheel and is very cheap. Probably find them @ Home Depot, Lowes or Ace Hdware for ~$1.
miker64867 is offline   Reply With Quote
Old 04-22-2011, 11:54 PM   #4
2005 19' Safari
GLENDALE , AZ
You need an old-fashioned hubcap hammer. Use Google, Yahoo, etc. to search for topic, or look on EBay, Amazon, etc. The rubber part protects the wheel when using the pry bar to pop the baby moon off; then you use the rubber part to hammer it back on.
Old 04-23-2011, 02:49 AM   #5
1966 30' Sovereign
1963 22' Safari
orlando , Florida
I removed my '63 Safari moons with a crowbar.No damage. Very tough moons.
richie rich is offline   Reply With Quote
Old 04-23-2011, 05:33 AM   #6
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Not to "hijack" this thread, but if you change your rims- I've got the original split rims- how do you set up to be able to put the baby moons back on your wheels?
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 04-23-2011, 07:21 AM   #7
1972 Travelux Princess 25
Cobourg , Ontario
If you mean what I think you mean the old wheels had clips. Newer wheels had bumps.
If your wheels have broken clips you can get replacements and rivet them on. There was a thread on this last year but to cut to the bottom line, do a web search for antique Chevrolet truck restoration parts sellers. They have the appropriate clips and they are not expensive.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Road Trip! Coast to Coast SilverRanger On The Road... 44 02-16-2011 07:18 AM
Can't stomach screw holes in new Airstream interior... dekew Upholstery, Blinds, Walls & Interior Finishes 24 01-07-2011 09:34 AM
Baby Oil - the magic bullet Foiled Again Off Topic Forum 19 01-04-2011 11:37 AM
