Old 02-27-2010, 08:01 PM   #1
1967 24' Tradewind
1979 25' Tradewind
thermopolis , Wyoming
How to ID 2,600 rated 15" wheels??
I have read lots of the threads on wheels and have two questions:
I have located some new proper sized(?) trailer wheels and tires for a 66 Tradewind at an attractive price. Question-how can I tell if these wheels are rated at 2,600 or better?? My guess is that they are off a Chevy PU.
Second, the center hole size is about 3.568" Seems the replacement wheels are 3.65 center hole diameter. Is the fit so tight that these wont work??
I am waiting to go retrieve the trailer and want to arrive with wheels and tires ready to go. If I cannot verify the wheels will work I will probably buy just the tires and have the tires remounted when I arrive to pickup the trailer.
Cheers, John
amoretti is offline   Reply With Quote
Old 02-27-2010, 10:27 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I think wheels like tires are rated according to load range A to E. never heard of an A or B and don't know if there is an F etc. I don't know if there is a way to tell on a used wheel.
Old 02-28-2010, 06:17 AM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Often the weight rating will be stamped on the wheel, frequently inside so the tire must be off. Not a sure thing tho.
I have found wheels that look identical rated at 1600, 2300, and 2600
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-28-2010, 07:03 AM   #4
SteveH's Avatar
Common Sense , Texas
Personally, I'd be more concerned about the size of the center hole. I've seen wheels that are the same otherwise, and not fit because of a smaller center hole, such as Dodge 1/2 ton truck wheels won't fit on a Ford 1/2 ton truck because the center hole is smaller.
Regards,
Steve
Old 02-28-2010, 09:21 PM   #5
1967 24' Tradewind
1979 25' Tradewind
I have read wheels sold for an AS have a center hole of 3.650". The rims I have found have a center hole around 3 9/16 or about 3.562. Will they fit an Airstream? A 66 Trade Wind to be exact.
Thanks, John
Old 03-01-2010, 06:22 AM   #6
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Seems to me it`s a pretty tight fit on the center,I wouldn`t take the chance of transporting wheels,that won`t fit when you get there.Dave
easyride is offline   Reply With Quote
Old 03-01-2010, 09:27 AM   #7
Cheers, John
John.
The center holw for the steel Airstream wheel is 3 5/8" in diameter.
Also, the greater the weight rating of a steel wheel, the heavier it becomes.
The Airstream steel wheel, rated at 2600 pounds, weighs 25 pounds.
Less weight than that, means a lesser weight rating than what you need.
13" wheels DUNSKI 1961 - 1963 Bambi 4 05-01-2012 02:04 PM
'63 Tradewind for $600 and not arrested! 3Ms75Argosy 1959-69 Tradewind 152 05-31-2011 07:53 PM
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Correct Wheels "78" Ambassador Roadrunner Wheels, Hubs & Bearings 2 09-21-2009 03:14 PM
change from 14" to 15" wheels?? happiestcamp Wheels, Hubs & Bearings 8 05-02-2007 10:57 AM
