Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 03-29-2003, 01:09 PM   #1
qqq
qqq's Avatar
Profile:
Question How not to loose a hubcap
Any ideas on this subject
Hart
qqq is offline   Reply With Quote
Old 03-29-2003, 02:54 PM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Thumbs up Yep
qqq
Believe it or not, just remove them before you begin your trip..Then, after you're setup at the site..reinstall them. WORKS EVERY TIME..
This is what I used to do before I replaced my wheels.
BTW, I left my old hubcaps at A/S for anyone who lost one..You could call them and, see if they still have them..
ciao
AIR 807
53flyingcloud is offline   Reply With Quote
Old 03-29-2003, 03:32 PM   #3
amfab
Profile:
The Top Ten Ways how not to lose a Hubcap The Top Ten Ways how not to lose a Hubcap
At the risk of being really annoying. . .
#10 Keep them inside the trailer until you park
#9 Calculate postage, affix stamps and engrave your home address and "If found please drop into many mailbox".
#8 Duct Tape
#7 Print a picture of the hubcap(s) in question on the side of milk cartons.
#6 Superglue, (it can suspend a man in mid air!)
#5 Put a Homing transmitter on the Hubcap's ear.
Perhaps if we all donate a little money to the forum, a research team can be put together to tag Airstreamer's hubcaps. They then can be tracked and charted, and Airstream hubcap migration patterns can finally be known.
(My guess is there is a cave somewhere in Utah where they go to their final resting place.)
#4 Petition John Walsh for a brief segment at the end of his show.
He already does say "lets recap..." so it shouldn't be too hard.
#3 Keep the hubcaps in a large sock for a few days before you put them on the trailer. If one is lost, let your dog sniff the sock to pick up the trail.
#2 Outboard magnetic pickup arms (see diagram below).
#1 Sew your name into the hubcap's waistband.
-Andrew
amfab is offline   Reply With Quote
Old 03-29-2003, 05:20 PM   #4
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
magnets!
amfab
great post!
i love the magnet idea!
lol!
john
Old 03-29-2003, 07:28 PM   #5
74Tradewind
74Tradewind's Avatar
Profile:
Oh Goody
Can't you just imagine the fun things those magnets can pickup along the way.
I say get rid of the hubcaps and get the mag wheels and then install the magnets. Can't you just hear the talk around the campfire after a 500 mile day of magnet fishing.
Ciao, Brian
www.ISellThousandOaks.com
74Tradewind is offline   Reply With Quote
Old 03-29-2003, 11:11 PM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
That's what I like about you legacey people. Always engineering new ways to make things work.
For me, I may not have a lot of real wood in my A/S, but in the hubcap area, I'm all set with rims!
Eric
Old 03-30-2003, 12:34 AM   #7
qqq
qqq's Avatar
Profile:
Amfab,
How did you come up with so many solutions when I couldn't find one ! I called John Walsh!
Hart
Old 03-30-2003, 02:57 PM   #8
74Tradewind
Profile:
Duct Tape
Easy to use too.
Old 03-30-2003, 08:58 PM   #9
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
One could always weld the little buggers one!
Just bring a torch to change the flat.
>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 03-31-2003, 11:22 AM   #10
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Balancing the "complete" running gear, stops vibration and tires pounding the pavement.
Does wonders to keep your hub caps in place, when towing.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 03-31-2003, 12:46 PM   #11
Action
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
Will properly balanced running gear help on pot holes, railroad tracks, and highway pavement joints?
>>>>>>>>>>Action
Old 03-31-2003, 03:08 PM   #12
Commercial Vendor
Won't help by driving off a cliff either.
But the driver can by avoiding as many road hazards as well.
The very best way to "NOT LOSE HUB CAPS," is don't use any.That also has a fringe benefit for the careful driver when towing. When stopped, you can easily check the temperature of the hubs.
Nothing is fool proof. If you don't believe that, put it in the hands of a consumer, or an RV owner. They will prove you wrong, "every time."
Lets keep to basics.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
800-8777311
Old 03-31-2003, 06:02 PM   #13
Action
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
So, getting back to basics, check to see that the hub caps are correct for the wheel application. If the hub caps are loose when the wheel is stationary or it requires a sledge hammer to install them, then it ain't correct.
The tabs on the center of my wheels had been moved so when* I did get correct hub caps (from a RV wrecking yard) they were not snug. I adjusted the tabs on the wheels to securely hold the cap. And based on results (a 180 mile trip one way) the hub caps are doing just fine.
*It took me a month of chasing old hub caps at wrecking yards here locatlly with a rim from my bullet in my trunk to find 4 good hub caps. They were a bit rusty. So I plan on rechroming them soon. And they fit tight.
>>>>>>>>>>>>>>>>>>Action
Old 03-31-2003, 06:59 PM   #14
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Speaking of checking hub temps....
I bought this mainly for checking plug tray temperatures in the greenhouse, and circuit breaker temps. It will be a neat tool to have when checking hub and tire temps while on the road. They cost around $85.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Hubcap mmeburges1 Wheels 5 01-10-2004 09:26 PM
New used trailer, some loose trim JHarper Clearcoat, Exterior Paint & Trim 5 11-29-2003 08:13 AM
Hubcap for 76 Argosy TT BILLY SPIER Tires 9 01-12-2003 08:26 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 12:11 PM
moved and tore loose what happened overlander General Interior Topics 5 09-24-2002 07:50 PM
test
