Originally Posted by Zstream
I just removed the wheel and tire. Do I now unscrew the large eight sided cap? or does it pop off? Please help... if you you have seen this before. tks, Z. (I found a company that will repack my bearings if I can bring in the parts )
Your grease cap screws off.
Use caution, since they are no longer available.
If you damage the threads, your done.
On the other hand, that hub and drum was used on axles many years ago.
Your torsion axle, is probably shot.
If that's the case, then replace your axle with all new components.
The following article will help you check out the axle.
Dura Torque Axle
