Old 12-14-2010, 05:01 AM   #1
1975 Argosy 26
marrowbone , Kentucky
Help with rim specs for 26" 1975 Argosy camper!
I want to get 2 spare rims and tires for the Argosy. I already have the tire size; now i just want to make sure I get the right rim specs. Ive done all the research i could before finally asking someone on here. The only specs i could find were for a similar RV version, not the camper style.
Also one more question. Can a brand new 4.28 center bore wheel be used as a replacement where a 4.25 center bore rim was mounted? Thank you everyone!
-Tony
antman is offline   Reply With Quote
Old 12-22-2010, 10:31 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If the appliction is the same as regular Airstream (and I believe it is) then the spec is; 15" rim 6 lug on a 5 1/2" bolt circle with a zero offset and a 2600# load rating.
>>>>>>>Action
Argosy Specs? MuthaMustard All Argosy Trailers 22 09-01-2012 08:14 PM
Rim specs lpatkins Wheels, Hubs & Bearings 11 12-16-2010 11:17 AM
Centramatics -- 16" wheel rim size larry b Wheels, Hubs & Bearings 14 01-26-2010 04:38 PM
24" Airstream/Argosy Camper completely redone eBay Watch Airstreams on eBay 0 10-25-2009 02:10 PM
Vintage 1975? Airstream Argosy Camper Trailer NEED TLC eBay Watch Airstreams on eBay 0 09-09-2009 07:40 AM
