05-19-2015, 09:31 AM
#141
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Very nice wheels.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
05-19-2015, 09:39 AM
#142
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
I just downloaded both the 2015 and 2016 Classic Owner's Manuals. On page 4-2 in each version, the torque value for the standard SenDel aluminum wheels is 110 foot pounds.
So that is a downward value from that published at the factory for the same wheels on the Eddie Bauer model.
There has been a wheel lug separation reported on this forum when running 125 foot pounds.
Some old timers suggest 95 pounds for aluminum wheels, probably referring to the 15" wheels.
So the 110 foot pound mark seems to be between the two extremes.
Also noted that twin beds will be an option for the 2016 Classics per drawings in the 2016 manual.
05-20-2015, 06:45 PM
#143
San Leandro
Tire and wheel upgrade 73 Overlander
I've been following this thread for sometime now because it is time for new tires on our Overlander. I like the pictures of the SenDels and would like to use them on the Overlander. Does anyone know if I can use the 16" wheel and tire combination on a 1973 Overlander?
05-20-2015, 07:14 PM
#144
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
LT225/75R16 tires and correct wheels will fit. Way more than you probably need, but they will fit.
Lance
05-20-2015, 11:56 PM
#145
San Leandro
Thank you Lance,
When you say more than I will need, would you please elaborate?
05-21-2015, 07:04 AM
#146
Always learning
1972 29' Ambassador
Central
Just about the weight
Thank you Lance,
Sure thing.
I think your trailer probably has a gross weight rating of around 7,000 lbs with 3,200lb axles. So, the two axles can safely carry 6,400lbs. 6,400/4=1,600. Add a little excess capacity, say 15%, and you need tires that are rated to carry 1,840lbs. 1,600*1.15=1,840
The 16" LT225/75R16LRE tires are rated at 2,680lbs at 80PSI.
LT235/75R15LRC with a capacity of 1,985lbs would be more than sufficient.
If you have different actual weights, that may change your requirements.
Lance
05-21-2015, 10:12 AM
#147
San Leandro
Thank you Lance. The reasoning behind the 16" wheels is that I wanted to run the Michelin LTX A/T2 tires. My understanding is that the sidewalls are constructed differently and are heavier than the 15" tire. I'll research this a little more.
Thanks again
11-04-2015, 01:00 PM
#148
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Not to toot my own horn, but 20,000 miles towed, no blow outs, no flats. (knock on wood)
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
11-04-2015, 01:35 PM
#149
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Oh that's a risky post...
@living.somewhere.yonder | Instagram
11-04-2015, 01:53 PM
#150
2013 31' Classic
billings
, Montana
I have 2.5 years and 21000 miles on my original 15" gym's and they are close to the halfway point, I have 7700 lbs on the trailer axles, wil be installing the 16" michelins this winter....
11-05-2015, 05:21 AM
#151
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro
, North Carolina
Over kill on tires
There are several threads on tires/wheels, but the bottom line for me is to increase the safety factor while reducing the road shocks transmitted to the trailer itself.
I am now using 54 psi in my Firestone Transforce 225/75 16's. This is higher than the minimum, but increases the tires resistance to road hazards, if I am correct.
As I travel mostly alone, I do not want failure.
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
03-23-2016, 12:09 PM
#152
Nomadic
, USA
I get the last laugh for all of you who clogged up my thread about my use of the word "RIM"
Look what they called it on my truck
03-23-2016, 06:47 PM
#153
Always learning
1972 29' Ambassador
Central
I think the clogging can be attributed to one member, yeah?
Nice truck and it has cool rims along with the cool rims on the Airstream.
Lance
03-24-2016, 07:11 PM
#154
2013 31' Classic
billings
, Montana
I still don't think I will go over to the kenworth parts and tell the parts man ,"I need a couple new aluminum rims"....
03-24-2016, 07:43 PM
#155
2007 22' International CCD
Corona
Help Me Order My 16 inch Rims
It depends where the parts guy lives. It the South, they's rims, y'all.
When we first moved to Alabama from California, I had to translate 'Southern' for the kids for almost 6 weeks before the got the vocabulary internalized. What's a kid from San Diego going to do when the teacher says, in a heavy drawl, "Y'all put up yer books rat now, y'hear?" Just one tiny example...gotta love it. Good thing I grew up in Florida.
I wore a gag interpreter strip on my Scout Leader Uniform those days. Instead of Espanol, or Deutsch. Mine said "Southern Drawl".
03-25-2016, 06:07 AM
#156
CapriRacer
I'm in the
, US
In the tire industry, we say "rims". We say it that way because:
a) There can be confusion about what a 'wheel" is. A wheel could be the metal part, but it could also be the whole assembly. In fact, while most folks use the term "tire" to mean only the rubber part, some folks use the term to also include the metal parts.
b) From the tire's perspective, the only important thing about the metal parts is the "rim" - the hoop of metal that interacts with the tire - and NOT the part that connects the rim to the hub.
So don't be surprise when people use these terms inconsistently. Also don't be surprised there are grammar nazi's. It's part of the fabric of the human species.
03-25-2016, 08:50 AM
#157
Nomadic
, USA
It's a gag. But don't be surprised I achieve Poe's Law a lot: https://en.wikipedia.org/wiki/Poe%27s_law
03-26-2016, 10:06 AM
#158
2019 25' International
Traverse City
, Michigan
It's not an American truck, that probably explains it. 😉
"Don't let perfect be the enemy of better."
03-27-2016, 08:03 AM
#159
2007 25' Safari
Greensboro
, North Carolina
Does anyone need help?
Are folks still deciding on a 16" wheel, rim, thing that holds the tire, the part which carries the weights, where the bolts go, has the hub cap, etc., ???
I am still quite satisfied with mine from
http://www.trailertiresandwheels.com...-trailer-wheel
and my Firestone Transforce tires running 54 psi. Now about 10,000 miles on them and with the lower pressures a lot less beating up of the trailer.
On the Road 05.18.15 by Tommie Lauer, on Flickr
AIR #31871 KQ3H
08-17-2016, 02:11 PM
#160
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Great thread with tons of factual information helped us confidently order our new 16" wheels & tires. Hopefully, baby will be wearing a new set of shoes by sometime next week!
Our GYM tires are about 3 years old, with roughly 20K miles on them, so we felt it was time to change them out. Didn't want to spend more money on tires we don't like or continue to fret about possible ST tire failures, which is why we went with the upgrade.
