Old 02-26-2015, 07:30 AM   #113
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by BoldAdventure View Post
We had our tires inflated with Nitrogen. which should help with heat issues, I used the Michelin inflation charts to have mine inflated to 75PSI currently which is 8880lbs load rating on dual axle. I know a few running lower. I figure, once we are ready to hit the road, our full time load up is in both truck and Airstream, I will hit the scales a final time and adjust tire pressure down.
I attached the PDF here for everyone else also.
2 thoughts:
1) I hope everyone realizes that the heat a tire generates is unaffected by whether nitrogen or air are used as an inflation medium. Lots of folks who sell nitrogen inflation equipment have been incorrectly stating that it makes a difference - it doesn't. Those folks obviously benefit from distributing false information.
2) I hope everyone realizes that the tire load tables are MINIMUMS, not recommendations. (OK, they could be looked at as maximums if you come from the other direction.) I recommend that people inflate their tires to 115% of the maximum actual load.
And one more thought:
There is a simple test to see if you have overloaded your tires: Pressure buildup.
Anything under a 10% build up is good. Anything over 10% is not - and if you get 15% or more, you need to take action IMMEDIATELY! The simplest thing to do is slow down, but in the log run, a tire with more load carrying capacity (either a larger tire or one with a higher load range).
CapriRacer is offline   Reply With Quote
Old 02-26-2015, 07:45 AM   #114
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Slightly confused, but hoping I am understanding you correctly.
Do you mean 115% of the tire's maximum or 115% of the load I'm currently carrying?
Can you give an inflation example.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 02-26-2015, 07:46 AM   #115
Nomadic , USA
Originally Posted by Rocinante View Post
Checking furiously to see whether anybody really cares.
Nope!
I love your new rims / wheels / tires, Bold. Great job.
Thanks and that's what I thought while the thread was being derailed.
Old 02-26-2015, 08:55 AM   #116
2010 25' FB Flying Cloud
Davenport , Iowa
Air is 80 % Nitrogen and 20% Oxygen; so does that 20% make that much of a difference? NOT according to some tire dealers in the area, it is a hype to get more money.
Airtandem is offline   Reply With Quote
Old 02-26-2015, 10:45 AM   #117
1965 mustang's Avatar
Stoughton , Wisconsin
I prefer hoops for wheels and stickers for tires😆
1965 mustang is offline   Reply With Quote
Old 02-26-2015, 12:32 PM   #118
Is nitrogen a problem while on the road and you have a low tire? Every service station has an air compressor. Can you mix the two?
Old 02-26-2015, 02:26 PM   #119
Nomadic , USA
The atmosphere is 80% of the stuff, so yes, you'd just be displacing the volume of it in the tire.
Tirerack.com has plenty to say about Nitrogen: http://www.tirerack.com/tires/tirete...jsp?techid=191
Old 02-27-2015, 05:51 AM   #120
Tao
Tao's Avatar
2013 19' International
Chapel Hill , North Carolina
The last I have to say on the question:
The tire and rim issue is much like Engine and Motor.
Historically, a motor is driven by electricity, as is your house HVAC fan, where an engine is internal combustion.
Seems our society is not that focused on keeping the distinctions on many word meanings in the traditional manner.
One that grips me is "How are you Guys doing?" when we sit down in a restaurant - my wife with me. She is NOT, and never will be a "Guy". She's my "Gal".
Tao is offline   Reply With Quote
Old 02-27-2015, 08:30 AM   #121
switz's Avatar
2014 30' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I watch the pressure rise and it goes up about 10% or less when underway (75 psi cold rises to 81 or 81 psi). The tire temps do seem to be nearly 35 to 40 degrees above ambient air temperature with the sun shining.
Old 04-19-2015, 05:58 PM   #122
Nomadic , USA
Finally photos of the wheels & tires out and about. Very happy with everything.
Old 04-19-2015, 07:22 PM   #123
paiceman's Avatar
Upper St Clair , Pennsylvania
I like them, have the same, Tell me is your trailer high in the front or is it an illusion in the first picture on top. Mine actual rides the same, I've got a 30', towed by an F350 with an equalizer hitch set up and she rides just a little high.
SAFE TRAVELS
Bud & Alice (Bud posts)
Abby- Black Lab-TDI Certified
Hopey-Yellow Lab-TDI Certified
2015 F350 6.7 Diesel Crew Cab
USAF - Military Training Instructor (TI) - 68-72
Old 04-19-2015, 08:52 PM   #124
Castle Rock , Colorado
Nitrogen was put into very high performance, very high speed, very hot tires to prevent the oxygen from igniting the tire from the inside. It has nothing to do with the pressure.
kmlacroix is offline   Reply With Quote
Old 04-23-2015, 06:25 AM   #125
CapriRacer
CapriRacer's Avatar
I'm in the , US
Ah ...... Mmmmmmm ....... actually, no. Tires don't operate anywhere near their self-ignition temperature - even in severe racing conditions. The only time they will burst into flames is when something else overheats - such as brakes. And even if N2 is used, they will burn.
Old 04-24-2015, 12:13 PM   #126
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
And now back to our regular programming folks... tires, rims and wheels
AirForums Custom Search
Janet H is offline   Reply With Quote
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 08:43 AM
14 inch or not to 14 inch wheels.. busboy 1961 - 1963 Bambi 0 08-25-2013 10:19 PM
What about options on tires for 14 inch rims? AlamoRunner Tires 8 03-27-2013 11:16 AM
16 inch wheel 7 inch width? Wiremanranch Wheels, Hubs & Bearings 2 03-24-2013 06:16 PM
Offset for 16 inch rims Cos Wheels, Hubs & Bearings 6 07-30-2008 12:25 PM
