Old 02-25-2015, 08:38 AM   #99
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Thumbs up
We had our tires inflated with Nitrogen. which should help with heat issues, I used the Michelin inflation charts to have mine inflated to 75PSI currently which is 8880lbs load rating on dual axle. I know a few running lower. I figure, once we are ready to hit the road, our full time load up is in both truck and Airstream, I will hit the scales a final time and adjust tire pressure down.
I attached the PDF here for everyone else also.
File Type: pdf Pages from MICHELINTruckDataBook_Jan2011-2.pdf (49.5 KB, 60 views)
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 02-25-2015, 09:23 AM   #100
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Movement turns on the Dill senders.
See if this idea works.
Before mounting the tire, see if the installer can spin just the wheel with the Dill sender installed on the wheel balancer and power up the Dill receiver with all the receiver plugs in place. With the wheel spinning, I think the one that blinks would be the one moving. If this works, repeat for the other wheels.
What a real PIA.
A two second application of a tape with a letter on matching components is so no brainer.
Note that the Dill TPMS sender is the valve stem for the tire.
Old 02-25-2015, 10:33 AM   #101
Durango , Colorado
Maybe it is just an age thing or a demographic oddity but when I was young, if someone used the term "Rims" it was a sign that they were a non-mechanical moron who knew very little about vehicles.
All good mechanics used the proper term "wheels". To this day it bothers me when someone says "Rims" instead of "Wheels".
RVDreamer is offline   Reply With Quote
Old 02-25-2015, 08:29 PM   #102
Nomadic , USA
Thanks for the insult your highness.
Old 02-25-2015, 08:56 PM   #103
Durango , Colorado
I'm Sorry, Bold Adventure. I didn't mean for it to come off as an insult to you but I guess I could see how it could be taken that way. It was poor wording on my part and I am sorry if I offended you in any way.
I think this is more of a times have changed sort of thing because on these boards most everyone uses the term "Rims" instead of "Wheels".
My father was a mechanic and he would scoff at me if I used the term "Rims" in the 1960's. So I meant to comment just to see if anyone else was irritated by the constant calling of wheels. "Rims".
Old 02-25-2015, 09:11 PM   #104
Nomadic , USA
Ok then.
They are used interchangeably for as long as I've been in the car scene. But,
A "rim" is:
2 a : the outer part of a wheel joined to the hub usually by spokes b : a removable outer metal band on an automobile wheel to which the tire is attached
2 a : the outer part of a wheel joined to the hub usually by spokes: Actually when I read this, "Rim" applys, it does attach to the hub via lug nuts and studs. "wheels" mostly do not have their own hub.
Rims where on cars and trucks....in the early 1900's. The hubs (now that will really confuse you) were left on the car or truck and all you changed was the outer rim and the tire....this continued on trucks clear into the 80's and is still the case in some OTR applications.
I'd say the reality is, rim vs wheel is no different than gay meaning something totally different 50 years ago. Terms change as more folks use them and I'd argue marketing has helped shift that, as "Rims" as a word is also heavily used in marketing materials too by manufactures. It's just a product of a cultural whose language is every evolving.
Old 02-25-2015, 09:21 PM   #105
Tao
Tao's Avatar
2013 19' International
Chapel Hill , North Carolina
Having worked my way through school in the 60's pumping gas and doing mechanical work, including fixing a lot of flats, the operative terms I was taught:
Rim == the metal within the rubber.
Tire == what sits on the Rim
Wheel == the combination.
I remember being "corrected" by the shop owner - Georges Sinclair Station in Portage, MI, when I call them as you suggest. :-)
Tao is offline   Reply With Quote
Old 02-25-2015, 09:36 PM   #106
Durango , Colorado
Originally Posted by BoldAdventure View Post
Ok then.
A "rim" is:
Well this agrees with what I was taught.
The rim is the outer part of the wheel on which the tire is mounted.
The wheel is the entire element including rims and spokes which mounts to the hub.
These used to be separate things in the early 1900s but now they are all incorporated into the wheel.
Almost all dealers that sell wheels, car parts dealers, etc, refer to them officially as wheels.
The only time I hear the term "rim" when referring to the entire wheel are by consumers.
Old 02-25-2015, 09:40 PM   #107
Nomadic , USA
Being in web, I did a quick search, oddly enough first results show Tires, Wheels & Rims.
If you click on Rims & Tires for tire rack, the page is still wheels. I'd argue that the industry isn't doing much to educate the public, but it's probably a moot point by now as both terms are cemented, the later especially with my generation; since I feel like I'm the only one my age who opens up a dictionary when someone older says something.
Interesting discussion fellows.
Old 02-25-2015, 09:53 PM   #108
Durango , Colorado
Agreed, let's all blame industry for language confusion created by verbiage used for the sole purpose of making a buck!
Old 02-25-2015, 09:56 PM   #109
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Tire+rim=wheel
Read about it here-
Barrystiretech.com
Lance
Top is offline   Reply With Quote
Old 02-25-2015, 10:13 PM   #110
Durango , Colorado
Originally Posted by Top View Post
Tire+rim=wheel
Read about it here-
Barrystiretech.com
Well I quickly scanned the website you referenced but could't find anywhere where the wheel was defined as the tire + rim.
Oddly enough, I did click on the link to Tire Racks Tech Page http://www.tirerack.com/tires/tiretech/tiretech.jsp
and I found this reference to tire & wheel manuals. So obviously Tire Rack thinks tires and wheels are something different.
I checked my Ford owner's manual and "Rims" was not to be found. I only found reference to "wheels" as in 20" wheels.
Old 02-25-2015, 10:48 PM   #111
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
Checking furiously to see whether anybody really cares.
Nope!
I love your new rims / wheels / tires, Bold. Great job.
Rocinante is our 2014 International Signature 27FB
Old 02-26-2015, 07:18 AM   #112
CapriRacer
CapriRacer's Avatar
I'm in the , US
Just an FYI:
Within the tire industry, the word tire means the rubber part, the metal part that the tire sits on is almost universally called the rim. Rims can come in 2 varieties - a simple hoop shape, or the entire package that is attached to the hub - what lots of folks call a wheel.
The reason why the tire industry uses the word rim instead of wheel is that from the tire's perspective, the only important thing is what the tire interacts with. Its usage is also historic in nature having over 100 years of usage.
So folks need to be aware that the term rim is in very common usage and they need to be aware that its usage isn't going to change. People also need to be aware that these 3 terms are frequently used in different - and sometimes contradictory - ways.
It is what it is.
CapriRacer is offline   Reply With Quote
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 08:43 AM
14 inch or not to 14 inch wheels.. busboy 1961 - 1963 Bambi 0 08-25-2013 10:19 PM
What about options on tires for 14 inch rims? AlamoRunner Tires 8 03-27-2013 11:16 AM
16 inch wheel 7 inch width? Wiremanranch Wheels, Hubs & Bearings 2 03-24-2013 06:16 PM
Offset for 16 inch rims Cos Wheels, Hubs & Bearings 6 07-30-2008 12:25 PM
