Old 05-19-2015, 09:31 AM   #141
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Very nice wheels.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-19-2015, 09:39 AM   #142
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I just downloaded both the 2015 and 2016 Classic Owner's Manuals. On page 4-2 in each version, the torque value for the standard SenDel aluminum wheels is 110 foot pounds.
So that is a downward value from that published at the factory for the same wheels on the Eddie Bauer model.
There has been a wheel lug separation reported on this forum when running 125 foot pounds.
Some old timers suggest 95 pounds for aluminum wheels, probably referring to the 15" wheels.
So the 110 foot pound mark seems to be between the two extremes.
Also noted that twin beds will be an option for the 2016 Classics per drawings in the 2016 manual.
Old 05-20-2015, 06:45 PM   #143
San Leandro , California
Tire and wheel upgrade 73 Overlander
I've been following this thread for sometime now because it is time for new tires on our Overlander. I like the pictures of the SenDels and would like to use them on the Overlander. Does anyone know if I can use the 16" wheel and tire combination on a 1973 Overlander?
bhales is offline   Reply With Quote
Old 05-20-2015, 07:14 PM   #144
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
LT225/75R16 tires and correct wheels will fit. Way more than you probably need, but they will fit.
Lance
Top is offline   Reply With Quote
Old 05-20-2015, 11:56 PM   #145
Thank you Lance,
When you say more than I will need, would you please elaborate?
Old 05-21-2015, 07:04 AM   #146
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Just about the weight
Thank you Lance,
Sure thing.
I think your trailer probably has a gross weight rating of around 7,000 lbs with 3,200lb axles. So, the two axles can safely carry 6,400lbs. 6,400/4=1,600. Add a little excess capacity, say 15%, and you need tires that are rated to carry 1,840lbs. 1,600*1.15=1,840
The 16" LT225/75R16LRE tires are rated at 2,680lbs at 80PSI.
LT235/75R15LRC with a capacity of 1,985lbs would be more than sufficient.
If you have different actual weights, that may change your requirements.
Lance
Old 05-21-2015, 10:12 AM   #147
Thank you Lance. The reasoning behind the 16" wheels is that I wanted to run the Michelin LTX A/T2 tires. My understanding is that the sidewalls are constructed differently and are heavier than the 15" tire. I'll research this a little more.
Thanks again
Old 11-04-2015, 01:00 PM   #148
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Not to toot my own horn, but 20,000 miles towed, no blow outs, no flats. (knock on wood)
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-04-2015, 01:35 PM   #149
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Oh that's a risky post...
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 11-04-2015, 01:53 PM   #150
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I have 2.5 years and 21000 miles on my original 15" gym's and they are close to the halfway point, I have 7700 lbs on the trailer axles, wil be installing the 16" michelins this winter....
Old 11-05-2015, 05:21 AM   #151
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Over kill on tires
There are several threads on tires/wheels, but the bottom line for me is to increase the safety factor while reducing the road shocks transmitted to the trailer itself.
I am now using 54 psi in my Firestone Transforce 225/75 16's. This is higher than the minimum, but increases the tires resistance to road hazards, if I am correct.
As I travel mostly alone, I do not want failure.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 03-23-2016, 12:09 PM   #152
Nomadic , USA
I get the last laugh for all of you who clogged up my thread about my use of the word "RIM"
Look what they called it on my truck
Name:	2016-03-23 06.10.40.jpg
Old 03-23-2016, 06:47 PM   #153
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I think the clogging can be attributed to one member, yeah?
Nice truck and it has cool rims along with the cool rims on the Airstream.
Lance
Old 03-24-2016, 07:11 PM   #154
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I still don't think I will go over to the kenworth parts and tell the parts man ,"I need a couple new aluminum rims"....
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 07:43 AM
14 inch or not to 14 inch wheels.. busboy 1961 - 1963 Bambi 0 08-25-2013 09:19 PM
What about options on tires for 14 inch rims? AlamoRunner Tires 8 03-27-2013 10:16 AM
16 inch wheel 7 inch width? Wiremanranch Wheels, Hubs & Bearings 2 03-24-2013 05:16 PM
Offset for 16 inch rims Cos Wheels, Hubs & Bearings 6 07-30-2008 11:25 AM
