Originally Posted by Chitown AirStreamers
A lug nut stem- one on each wheel hub sheered off. So my mechanic & I took the wheels off , then the hub that has the stems attached. There is a plate on the back of this hub which is rivited to the hub then the stems go in from there. I cannot find these stems & according to the shop where I took these hubs to get the plate taken off- these stems have a different shoulder then a regular stem that you can buy at any parts store....can anyone help me out? Where can I get these? What about the grease seals-...where can I get these?
We have some of the old "stems".
Please forward a photo with dimensions.
To replace the stems, you must first remove the armature plate from the hub and drum. You can refasten them with flush bolts and regular nuts.
If your grease seals are marked 292100, the only place that will have them is Airstream.
We ordered some, and they were off by about 1/4 inch.
I don't know if Airstream received the correct seals as yet.
We used to have those seals made. But today, we still can have them made, if we purchase 500 of them. No thanks.
