Old 11-24-2012, 06:37 AM   #15
1988 25' Excella
Trumbull , Connecticut
aluminum wheels
Hello All. Google "TREDIT" and they have lots of wheels at a reasonable price.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 11-26-2012, 12:09 PM   #16
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the Information
Special thanks to Gold and Silver for the link to the website for Sendel wheels. They are the ones I saw at Jackson Center.
Someday I will upgrade to 16" wheels and LT tires. I'm nervous with my 15" C rated Marathons. A bad choice for a trailer as heavy as mine.
David
Old 11-26-2012, 02:27 PM   #17
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
David
I agree that the 16" wheels are a good choice. However, you have that load spread over 6 wheels. The real load is on something like a 32 that has almost the same load on 4.
Vaughan
Old 11-26-2012, 05:31 PM   #18
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I have a 31. Does that mean I have 31/32nds of real load?
Ken
Old 11-26-2012, 05:43 PM   #19
1983 34' Excella
1967 24' Tradewind
Images: 32
Ken
Yeah, don't you feel about 1/32 lighter?
Vaughan
Old 12-12-2012, 04:03 PM   #20
Mixter's Avatar
1976 27' Overlander
I see this is an old thread, but the wheels looked familiar. Are these them?
Aluminum Trailer Wheel Style: PHENOM Size: 16 x 6 Bolt Pattern: 6 x 5.5 Bore Size: 4.25 Load Rating: 3200 lbs @ 85 PSI Offset:0
Mixter is offline   Reply With Quote
Old 12-12-2012, 05:21 PM   #21
fr8tshaker's Avatar
2006 34' Classic
Sioux Falls , South Dakota
..... I liked the fact that the backside of the wheel was painted black, which made the front side stand out even more.
David
My 16 in wheels have the black background.
The black background behind the wheels is centramatics painted black. If you look closely at the pic you posted you can see part of the lettering.
'shaker
2006 34' Classic LTD
2010 Ford F250 PSD
Hensley Arrow Hitch
fr8tshaker is offline   Reply With Quote
Old 12-12-2012, 07:44 PM   #22
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I believe these are the same 16" wheels as available from JC:
Sendel model T03-66655T wheel rated 3,580 pounds @ 80 psi
Old 12-23-2012, 04:18 AM   #23
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It appears the new Eddie Bauer Sport trailers use the Sundel 16" wheel. I think Mixter found the exact wheel I took a picture of and posted in the opening stitch of this thread. That wheel has a little more detail on it.
There are many aftermarket wheels to choose from. Getting the correct wheel specifications for the Airstream is very important, especially offset and rim width.
I appreciate all the research and information you folks provided on this special 16" wheel. I have all I need to make a purchase.
David
Old 12-30-2012, 02:31 PM   #24
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Let's not forget about wheels that the material composition and method of construction bear on our concerns.
Steel wheels may not be pretty, but they'll deform under a load before they break. There are RV'ers from the world of trucking who will have no other kind.
Aluminum wheels may be cast, forged, or machined from billet. That roughly follows the upward price curve. The final two may not have much relative strength difference, but the usual cast aluminum wheel will crack & break before all other types. There are different kinds of casting methods, too.
Then there is finish work. Etc.
Keep it in mind as you shop. Some wheels are cheap for a reason.
The ALCOA wheels (a brand also used on 18-wheelers) once used by A/S were, I believe, a very good choice. More expensive, and I don't think they today market a TT sized wheel for our purposes. Keep the brand -- and its' details -- as a benchmark.
