Old 10-21-2019, 01:42 PM   #1
Sault sainte marie , Michigan
Hard time finding wheels
I am restoring an Airstream for a friend and I am having a hard time finding wheels. I have attached the bolt pattern and the diameter when measured from stud to stud is 7.25. That seems odd because most wheels I see have a 5.5 diameter. Anybody have any suggestions?
6 bolt pattern.
Nick
nhuyck is offline   Reply With Quote
Old 10-21-2019, 02:28 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
You should be able to find what you need here:
https://www.vintagetrailersupply.com...?Search=wheels
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-21-2019, 05:57 PM   #3
They seem to only have 5.5” diameter (lug to lug) wheels and mine is 7.25”. That’s where I am confused.
Old 10-21-2019, 06:10 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
What is the year and model of the Airstream?
Old 10-22-2019, 09:39 AM   #5
I am having trouble narrowing that down, too. I have attached the plate next to the entry door, but the metal plate next to the door says 7004.
Any help would help, thanks,
Nick
Old 10-22-2019, 09:44 AM   #6
1981 31' Excella II
New Market , Alabama
So what year is this Airsteam? Standard 6 bolt rim is 5.5" bolt circle. You might have to replace the whole axle.
Perry
Old 10-22-2019, 10:43 AM   #7
Olscot's Avatar
1976 31' Sovereign
Eagle Point , Oregon
wheels
Older 1/2 Chevy pickup wheels fit some of the older Airstreams. Fairly popular in lots of custom wheels and plentiful in wrecking yards.
1995 F-250 ExCab Long Bed 7.3 Powerstroke 2WD
Metal Topper w/rack for boat usually full when camping
14 mpg Towing 17-20 Empty
1976 Sovereign 31' CB Rear Twin towed 'on the ball'.
Olscot is offline   Reply With Quote
Old 10-22-2019, 12:47 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Going with a passenger car or light truck wheel might get you into some excitement.
The trailer wheels are rated at 2500 to 2600 pounds. Most passenger car or light truck wheels are rated for much less than that.
The forces that trailer wheels are subject to, especially during turns on a dual axle trailer are far different than a passenger car or light truck.
>>>>>>>>>>>>Action
Old 10-22-2019, 01:01 PM   #9
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
6 lug on 7.25 lug pattern
I found these posts on your lug pattern that suggests its from Dodge, International Harvester, Ford trucks through the 60's.
https://forums.ihpartsamerica.com/sh...ad.php?t=10629
https://www.ford-trucks.com/forums/6...ly-wheels.html
I'm curious to see a couple photos of the axle(s) on the trailer. Are the brakes hydraulic? Perhaps someone got creative with swapping parts from a truck??
Regarding the id plate I have to wonder if its original to the trailer. I don't recall ever seeing one that was not pop riveted on from the factory. The fact that it doesn't show LA and Jackson Center listed probably places it prior to the 60's. Photos of both sides of the trailer would help identify the model, since no model plate is next to the id plate.
Does the owner have a title? What year is listed there?
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-22-2019, 01:22 PM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Your trailer is likely way older then this.
Airstream stopped manufacturings trailer in California in 1979.
>>>>>>>>>Action
Having a Hard Time Finding the Right Size Microwave ScottandMoni Stoves, Ovens & Microwaves 0 05-23-2019 08:50 PM
Finding unconventional places to park - full time kristiperry Full-Timing 12 09-17-2017 06:57 PM
Help Finding 16" 6 Lug Aluminum Wheels dbj216 Wheels, Hubs & Bearings 23 12-30-2012 03:31 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 06:31 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 08:49 PM
