Old 03-18-2016, 11:17 AM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by WestieHouse View Post
I'm looking at Progressive Dynamics http://progressivedyn.com/mobi/index.html
Or maybe just a smart multi-stage charger from Xantrex
http://www.xantrex.com/power-product.../overview.aspx
Me, too, but...
I gotta know what I have to know what to get.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-18-2016, 11:21 AM   #16
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
Originally Posted by m.hony View Post
1. tires replaced
2. lug nuts replaced
3. need new converter for AGM batteries- Which converter?
I chose the 55 amp converter replacement kit, $213 at
http://www.bestconverter.com/55-Amp-...l#.VuwyW-IrJhE
(Recommended by Randy, the main man at Best Converter.)
The installation is supposed to take 30 minutes, but I took significantly longer (even tho I have decades of electronics experience). For the installation process, see:
http://www.bestconverter.com/Magnete...II_ep_8-1.html
Originally Posted by Wayne&Sam View Post
An 8 point socket helps a lot, but I agree the lug nuts are cheesy. The other four things you listed however were things you upgraded by choice and weren't necessary to use the trailer.
While I acknowledge that I chose to upgrade & that the trailer worked without any of the upgrades, I respectfully suggest that the inherent quality of the items that I chose to upgrade etc. were, in my opinion, below the quality of usual AS components & should not have been included in a 28 ft trailer with a MSRP of approximately $90,000. Furthermore, there is overwhelming evidence presented in posts in this Forum that both the Marathon tires and flooded batteries are problematic & less than ideal, and that if AGM batteries are installed, a three-stage charger is needed. For $90,000, I would have expected the manufacturer to have ironed out & omitted components known to be problems. My false assumption!
Originally Posted by GCinSC2 View Post
Try reinstalling the cap, maybe put it in the socket first. then try again to remove. Solid lug nuts exist. Sorry don't have my part number right now but they exist.
The cap itself is split entirely down its side, so in my hands, at least, none of my sockets work with it.
Several of you suggest one-piece, triple-chromed, solid lug nuts, for example, by McGard. Thank you for your suggestions. I agree. So far, I've found AccuWheel LNA-12000C6 Chrome Bulge Acorn Wheel Lug Nuts (1/2"-20 Thread Size) 1.4" Tall - Pack of 24 Lugnuts for $20 on Amazon:
http://www.amazon.com/gp/product/B00...A295M0YSJKHL0M
They've gotten five stars, & I'm inclined to give them a try.
Gentlemen & ladies, thank you for your generous & helpful comments & suggestions. This Forum has been a Godsend for me; thank you all.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 03-18-2016, 11:39 AM   #17
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Not to down play the problems, but our Newmar Luxury 38' Coach came with two piece lug nuts as well and lets just day it cost considerably more than any AS.
Our 2015 FC with factory installed Sendel Wheels and Michelin LT tires has one piece chrome lug nuts on the wheels?
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-18-2016, 12:14 PM   #18
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
The Gorrila nuts use a special spline socket. That is either a terrific idea or a terrible one depending on your perspective. I kind of like it. You may not. Can't go wrong on the McGards. We are happy with the Gorrilas and they were in stock and not so expensive.
A fibreglass hole in the water requires you add a long line and a hunk of metal for brakes, a horn and signal flares to warn others you are around, a long stick to push away or grab a parking spot, rubber balloons to defend from parking dings, a radio, a GPS, and a whole slew of other gear so you can use it with any enjoyment .... including better batteries, a multistage charger, and solar panels. Lots of hobbies cost money and the price is the same. All you can afford. Think of the money you are saving with AS.....no anchor required. Pat
Old 03-18-2016, 12:16 PM   #19
m.hony's Avatar
2013 30' Classic
Your trailer had the upgrade from the factory.
Many of us did the upgrade later.
TAC #MS-10
Airforums #70955
Old 03-18-2016, 12:29 PM   #20
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Moosetags, thanks for the information on the lug nuts. I found the best online price for the McGard 64010 lug nuts at Summit Racing who sells them for $8.97 for a package of 4 lug nuts. I ordered 6 packages (24 lug nuts) and the shipping to NJ was $9.95.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 03-18-2016, 12:59 PM   #21
m.hony's Avatar
2013 30' Classic
I went the $19.95 route for 24 lug nuts from Amazon-
No rust so far-
TAC #MS-10
Airforums #70955
Old 03-18-2016, 02:40 PM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We just have different perspectives. I've made upgrades to my AS too, but I'd bet the overwhelming majority of AS owners are happy with the way the are equipped from the factory and never see the need to change a thing. Airforums is a microcosm of the AS world, where you're more likely to encounter folks who tweak and upgrade. But even out of these, most probably don't.
2012 Dodge Durango Hemi/AWD
Old 03-18-2016, 02:54 PM   #23
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
No rust so far-
Ditto
kscherzi is offline   Reply With Quote
Old 03-18-2016, 03:12 PM   #24
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
I feel the op's pain.
This just happened to me today!!
I got Centramatics last fall and went to put them on. Note that my trailer is 2004 and I bought it used and I had a tire shop change the tires to LT tires last fall.
So I got out my trusty tool box and started to loosen the nuts. They felt strange in the socket. The "corners" are slightly rounded. I too discovered this is due to the chrome cover over the actual nut. A 3/4 socket was a little tight so I ended up using a 19 millimeter. It worked ok, until I got to one lug at 13/16. Then another lug a little smaller that I totally mangled. After much struggling, I finally got them all off and ruined 2 of them. I had to hammer a 12 point socket onto the nut to get it to grab.
I am taking a 2500 mile trip and leaving on Sunday. Luckily a tire store had 24 new ones in stock that actually have sharp edges and fit the socket. I'm 80 dollars poorer, but know that I can get them off much easier if the need arises.
sb55 is online now   Reply With Quote
Old 03-18-2016, 03:17 PM   #25
m.hony's Avatar
2013 30' Classic
Name:	ImageUploadedByAirstream Forums1458335850.290204.jpg
My $19.95 Amazon lug nuts still look nice.
TAC #MS-10
Airforums #70955
Old 03-18-2016, 04:42 PM   #26
2016 30' Classic
Santa Rosa , California
I partially stripped the outside of one of my AS lug nuts using a 12 point socket. I now use a 6 point socket for a really secure fit. I dont know if a 6 point socket (vs 12) would reduce the likelihood of the stock AS lug nuts from breaking, but thought I would toss the idea out there.
phann is offline   Reply With Quote
Old 03-18-2016, 05:05 PM   #27
m.hony's Avatar
2013 30' Classic
The original lug nuts' chrome covers distort and crack even with the correct size 6 point socket.
TAC #MS-10
Airforums #70955
Old 03-18-2016, 05:26 PM   #28
sb55's Avatar
Attachment 259008
I am sure that I got hosed spending almost $80.00, but the luxury of shipping time was not an option for me at this time.
Ps. Amazon Prime is great for those of us who live in the boonies.
Converting from lug bolts to studs and lug nuts tim781996 Wheels, Hubs & Bearings 7 11-22-2014 09:23 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
lug nuts bambi david h Axles 2 02-10-2003 08:59 AM
