Old 03-08-2008, 10:18 PM   #1
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Greenball 15" alloys?
I'm looking at new wheels and tires for my very recently acquired '61 Overlander. Steel rims with Goodyear 225/75 R15 LRD tires are option #1; however the speed rating leaves me concerned which is not what I'd like. (65mph).
I found some pleasant looking wheels (6 lug) and wondered if anyone had knowledge of them with regard to Airstream usage? 15 inch GBC 2000 6 Bolt Aluminum Trailer Wheel also Greenball: TRAILER WHEELS - ALUMINUM GBC2000 They would run another $200 total over steel which seems a worthwhile upgrade. I guess a little more when lug nuts are added on.
With regard to the tires are Maxxis (sp) the only trailer specific tires in 225/75 15 Load range D that are rated above the 65 mph that limits the Marathons?
truckasaurus is offline   Reply With Quote
Old 03-08-2008, 10:35 PM   #2
_
hi trucks...
it is commonly mis-referenced here that the marathons are speed rated to 65mph.
this isn't correct, they are load rated/tested at 65 mph....this is a distinct difference from a traditional 'speed rating'...
even the goodyear website for marathons covers what to do when 'towing at 65-75 mph' with marathons....
we've covered this issue dozens of times already, so search some and find the info and links....
ALL ST tires carry the same designations, of load testing at 65 mph.
greenballs are no different than marathons (some are even made by goodyear)
maxxis is different because of a nylon cap layer...
regardless of which tire u chose, IF you plan to tow fast, they must be inflated to higher pressures.
so using a tire rated higher or that is stiffer may have negative consequences on your '61, which came with bias ply tires.
bias tires are still available, but i sure won't choose them for towing in heat, at speed or for longer distances...
cheers
2air'
Old 03-08-2008, 10:38 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I've run across that rim while researching aluminum wheels. They are sharp looking. I am still undecided as to what rim style I will go with. I haven't made the final decision whether to go with 15" rims or make the jump to 16" which I am favoring. I have one new Maxxis tire with less than 1000 miles on it purchased last October to replace a blowout. Wheel size will all depend on whether the Centramatic balancers will fit the 15" or not. I do not favor any spacers between the drum and wheel should it be needed. I'll be talking with the Centramatic folks closer to April about this.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-09-2008, 10:30 AM   #4
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
2air,
Why do you rudely continue to point this out. Keep in mind that the "We" you speak of does not include newer members. Some people prefer to discuss issues rather than just read through the archives. As far as I know there is no prohibition regarding discussing a topic that has been addressed before. If you prefer to not re-discuss an issue then I would suggest leaving yourself out of the conversation.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 03-09-2008, 10:44 AM   #5
1960 33' Custom
2air, interesting information. I thought I'd searched the topic to death but I must have missed that the salient point. Sounds like the Marathons are back in the running. Just need to decide on those rims now.
Old 03-09-2008, 12:36 PM   #6
_
Originally Posted by byamcaravanner
..read through the archives.
bc
there is NOT 1 keystroke of rudeness (expressed or implied) in this thread except yours.
this thread is IN the wheel sectiion, not tires, but the o.p. may find it useful to look over the tire threads too...
the VALUE of searching is that MANY of the best, complete and detailed answers on COMMON topics are already written.
along with LONG heated arguements on some topics.
so those looking for answers may find dozens of useful replies,
from folks who've tossed in their 2 cents already...
while the just asked version of the same question goes unanswered or gets little play.
Originally Posted by truckasaurus
...I thought I'd searched the topic to death but I must have missed that the salient point. Sounds like the Marathons are back in the running...
trucks...
which tire brand usually becomes a very HOT topic here...
tire selection is very personal,
my point is ST tires like greenballs and marathons aren't very different and
cheng shin (maxxis) is the new hot choice for some, but with little user info (read failures) collected...
otoh they DO have a LONG history of making jinrikisha tires!
here are a couple of links for ya on this issue which may or may not b useful...
but there are 100s others too.
http://www.goodyear.com/rv/pdf/marat...nfo_032806.pdf
see pages 9-13 here and the weight/inflation tables that follow...
http://www.goodyear.com/rv/pdf/rvbrochure.pdf
posts/threads...
http://www.airforums.com/forums/303973-post27.html
http://www.airforums.com/forums/355140-post115.html
http://www.airforums.com/forums/f438...ure-36206.html
i've had good results with the marathons but who knows what 6 will b next...
http://www.airforums.com/forums/f438...ons-27999.html
nothing in my first reply 2u suggests not to ask questions ANY question,
but learning to use ALL of the resources here is very useful too!
have FUN selecting wheels, there are lots of good threads on wheels, with SHINEY PICTURES TOO!
cheers
2air'
Old 03-09-2008, 01:06 PM   #7
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
2air,
Hi byamcaravanner,
I think 2air is offering new information and also suggesting new posters do some research before asking more of the same questions.
It can get redundant re-hashing the same advice over and over and some of that advice gets deluted with repetition. 2air does have his magic fingers on the collective past regarding previous posted knowledge and experience. That becomes part of the thread along with a (sometimes) gentle reminder to look a few things up.
We have all contributed to threads about a question about the final aspects of the project only the find out later this poster is still trying to decide weather or not to convert the tube frame to square channel. A bit early to be asking about fabric and foam choices, don't you think?
I like the new questions too.....but sometimes it seems like some just want to start a thread and be fed information without doing some digging themselves. And then drop it!
I do not think 2air was rude...maybe just blunt. or curt. or succinct. (I had to look that one up)
safari62 is offline   Reply With Quote
Old 03-09-2008, 03:43 PM   #8
1960 33' Custom
I am interested in the Goodyear information, I get the 65 mph load rating but still haven't found the info telling me it has a speed limit higher than 65mph stamped on the sidewall. Without that stamp the "speed limit" is still the same as the load rating if I follow the advice on their website to the letter?
Anyhow I've read so many tire posts now I feel like I have a plan. Choose trailer wheels, add tires designed and rated for the job (ST) and add TPMS to give me a heads up if/when pressure and heat become a more prevalent factor.
I still like the wheels "Greenballs" that I posted about so I think I'll give them a call on Monday to check the offset and go from there.
Old 03-09-2008, 04:13 PM   #9
_
...I get the 65 mph load rating but still haven't found the info telling me it has a speed limit higher than 65mph stamped on the sidewall. Without that stamp the "speed limit" is still the same as the load rating if I follow the advice on their website to the letter?...
that's correct basically.
all currently stamped ST tires are only tested for temp and load ratings at 65mph.
ST tires don't get a traditional utog or 'speed rating' like passenger car tires do...
Tire Tech Information - Uniform Tire Quality Grade (UTQG) Standards
Goodyear Marathon Radial at The Tire Rack.
IF 65mph was meant to convey the modern/current speed rating...
that would basically mean the tire is tested to perform at that speed for 10-15 minutes before destruction...
Tire Tech Information - How to Read Speed Rating, Load Index & Service Descriptions
of course that is what has happened to a few, from reports here.
also consider (at least in the lower 48) towing speed limits are 65 or LESS in most states; what are the canadian towing speed limts?
so there is very little upside for testing or certifying ST tires above 65 mph.
but i can report towing 1000s of miles at 72 mph with out issues and with tire temps no higher than towing at 65.
proper inflation and maintaining that inflation is key, since pressure drops of 15 psi are to be considered the same as GOING FLAT...
good looking wheel choice too!
cheers
2air'
Old 03-09-2008, 04:35 PM   #10
1960 33' Custom
Speed limits are much the same 110 KMPH or about 69 mph. I drove from South Carolina back here in November (with my new truck but no trailer) and Montana was about 70 or 75 mph if I recall, just made me think of a bit of an extra safety margin. As a complete newbie Airstream hualer I doubt if I'll be setting any land speed records (unless things go badly out of shape in the Rockies!)
Once again thanks for pointing me in the right direction.
Old 03-09-2008, 08:34 PM   #11
davidz71's Avatar
1986 25' Sovereign
truckasaurus,
I forgot about this bookmarked page I found. It gives you a much better idea of what this wheel looks like on a boat trailer.
MacGregorSailors.com :: View topic - Aluminum Trailer Wheels (15-inchers)
Craig
AIR #0078
3.73 rear end
Old 03-09-2008, 09:14 PM   #12
1967 28' Ambassador
1970 29' Ambassador
I'm glad you meant no harm, but where I come from, if I had this sort of verbage directed at me I would consider it being chastised. I'm just offering my opinion that it should not be a requirement for people to "search the archives" and thus no need to point this out EVERY time a previously discussed topic is mentioned by a newer member.
Steve & the crew
Old 03-09-2008, 10:01 PM   #13
1967 28' Ambassador
1970 29' Ambassador
Thumbs up
It may be just me, but I've got my flooring and fabrics all picted out and I'm still welding on my frame and hashing out what sub floor to use. How else would I know what shade of salmon to paint the frame. LOL!
The points you and 2air make are all good. I'm just offering some perspective from a newbie to which many of these topics are new territory. We all want to enjoy the exchange that happens through "coversation" ...even if, sometimes, we've already found our answer in the archives.
Steve & the crew
Old 03-09-2008, 10:48 PM   #14
1960 33' Custom
Thanks Craig, if these are zero offest I'm good to go, a picture is worth a 1000 posts (or maybe something close).
Carlisle or Greenball Tires Aluminati Tires 18 10-27-2007 10:14 AM
Confusion on "weatherstripping" vs. "gasket" pinkflamingoes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 03-20-2005 02:55 PM
