Old 09-03-2017, 08:37 PM   #1
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
Ford Trailer TPMS Kit
Ford offers a kit for the 2017 F250 which integrates trailer TPMS functionality into the TV's standard TPMS system. All tires can then be monitored from the multi-function screen in the instrument cluster.
The specs for the kit indicate that the included trailer wheel sensors will only fit wheels with a J type flange wider than 3.5" (88.9mm) and a .452" (11.48mm) valve stem hole.
Does anyone know what the spec is for these dimensions on an Airstream wheel, specifically for the 16" wheels that come on the later Classics? Has anyone used this kit?
https://accessories.ford.com/kit-tpms-sensor.html
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 09-03-2017, 11:09 PM   #2
mikeinca's Avatar
2018 30' Classic
It occurs to me that if I at least knew the manufacturer of the 16" wheels on the Classic I could probably track down the info I'm looking for, so if anyone knows that.....
Thanks.
200W portable solar
Old 09-03-2017, 11:22 PM   #3
Byron Center , Michigan
In another post switz mentions that they are 16" SenDel T03-66655T wheels that were used on 15/16 Classics. That should get you the data you're looking for. www.sendel.com has spec pages and contact info. 866-320-6891
YippieKiYa is offline   Reply With Quote
Old 09-03-2017, 11:30 PM   #4
mikeinca's Avatar
2018 30' Classic
That's a good lead. Thanks.
200W portable solar
Old 09-04-2017, 06:23 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
A little pricy but might be worth it for the convenience factor.
MICHAEL
Old 09-04-2017, 06:29 AM   #6
That's what I was thinking, too; it would be one less accessory/monitor in the cab.
Old 09-04-2017, 07:07 AM   #7
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Following as I have the kit but have not installed it as yet. Not sure why Ford did not make it a wireless thing. I also have the camera.
TinCan
graysailor is offline   Reply With Quote
Old 09-04-2017, 08:05 AM   #8
2018 27' Flying Cloud
Jacksonville , Florida
I just bought a new F-250. I wanted the TPMS feature as well, but the dealer stated that the truck must have the factory-installed Ultimate Trailer Tow Camera System in order to add TPMS. Also requires Sync3.
It would be nice to see the read-out integrated with the dash screen, but after looking into what's involved, I'm satisfied with an after-market wireless unit, which seems less of an undertaking.
Doodad is offline   Reply With Quote
Old 09-04-2017, 08:28 AM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Depending on which tires you have on your trailer, that also may be a concern. The Michelin's that come on some of the newer trailers have steel in the sidewalls. Ford cautions about this. It may or may not be an issue ....
Old 09-04-2017, 11:30 AM   #10
Cave Creek , Arizona
I have the Classic and the 2017 F250. I added the Ford TPMS kit. It works as advertised- no issues whatsoever. I mounted the sensor pickup on the side of the battery box because I found it the easiest place on the frame to drill for the sheet metal screws.
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 09-04-2017, 12:50 PM   #11
mikeinca's Avatar
2018 30' Classic
Excellent. And it sounds like you were able to DIY which is also encouraging. Thanks for the feedback, Pete.
200W portable solar
Old 09-13-2017, 08:43 AM   #12
Cumming , Georgia
Tst tpms
TST TPMS is used on Airstreams, and will not interfere if you have TPMS on your towing vehicle. It can also be used on your towing vehicle.
http://outsideinterests.info/article/top-9-airstream-accessories/
Mike Benson
TST TPMS
mbenson1234 is offline   Reply With Quote
Old 09-13-2017, 09:57 AM   #13
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I have a 2017 F350 and installed the Ford tpms system on my 28ft international I will also mention that I have Michelin Rib tires. .I mounted the control box to the center of the forward fixed axle with zip ties.Programming was simple and it works perfectly.No regrets
Old 09-14-2017, 07:57 AM   #14
TinCan
graysailor's Avatar
2016 30' Classic
Yesterday I did get the sensors installed on my Classic wheels. No leaks so I guess they work. I have not run the cables as yet so have not been able to test the system.
TinCan
2017 Ford Ultimate Trailer Camera & TPMS Airdog9 Towing, Tow Vehicles & Hitches 42 04-30-2018 08:22 PM
Ford-trailer TPMS system GoWhereTowed Towing, Tow Vehicles & Hitches 2 07-11-2016 10:12 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Good and Inexpensive TPMS Kit Akronguy Tires 3 05-07-2015 08:58 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
