Old 10-28-2012, 05:51 PM   #1
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
First Self Servicing
I'm reviving my long sleeping Sport 22, which has been stored on jacks for almost four years. After reading this forum, and watching related You Tube instructional videos, I'm doing my own hub service for the first time. Removing, cleaning, inspecting, and re-greasing the bearings is not as tough as I expected, and the brakes look good. Thanks again to all in this forum for great advice, and encouraging folks to take an active role in learning Airstream sub-systems!
I've used a product called Brakleen, which works great on all the metal and brake surfaces. The strange white spot is a clean shop towel, keeping dirt out of the bearing traces while I clean the bearings.
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 10-29-2012, 09:18 AM   #2
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Cudoes to you. Hope you adjusted the brakes after the lube.
Ahab is offline   Reply With Quote
Old 10-29-2012, 10:56 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I usually use a file to remove the rust build up ring that occurs at the inner circumference of the braking diameter. It makes it easier to reassemble without backing the brakes off that far. It also reduces the amount of clicks you need to make to properly adjust the brakes.
Old 10-29-2012, 04:54 PM   #4
Whizzo's Avatar
San Antonio , Texas
Images: 18
Yes, thanks. I quite slowly "clicked the star" then backed off a bit. And cleaned out the rusty reside.
