Old 05-27-2012, 03:08 PM   #1
Orange , Texas
Rivet Engine #9
What type of wheel bearing grease should be used on my 1996 AS Excella?
m&bkelley is offline   Reply With Quote
Old 05-27-2012, 03:39 PM   #2
There are many kinds to use.
A good one is a "high quality" marine grease.
It helps when some moisture gets into the bearings.
Make sure you replace the grease seals, too, with high quality, double lipped and with a spring.
Old 01-20-2013, 10:42 AM   #3
Laughlin , Texas
Part number
Is there a particular part number for that grease seal?
Sam Adams is offline   Reply With Quote
« Tire rims | Top | Lug Bolts »
