Old 11-19-2006, 05:54 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Exclamation Dyna Beads wheel balance
Anyone use these to balance the wheels? I assume they should balance the running gear as well.
The site says high-density ceramic bead that, when easily installed, continuously balances your tires as you drive. The amount of material will distribute itself in weight and position dependent on the balance requirements of the individual tire.
The result is a smooth, vibration-free ride, derived from our balancing media that is always repositioning itself as the tire wears. If you own a pickup truck, RV and want to get rid of those wheel vibration and tire cupping problems, then you need to move up to Dyna Beads!
looks like 3 oz per tire cost about $15, you install them thru the air valve, and intstall a special insert.
You need not take the tire off the wheel.
'77 Sovereign Intl 31' CB
Old 11-19-2006, 06:58 PM   #2
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
Never seen them till now,here is the same theory in a different approach. http://centramatic.com
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
S C Streamer is offline   Reply With Quote
Old 11-19-2006, 08:05 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
a different approach, with a different $$$ by several hundred bucks.
Old 11-19-2006, 09:48 PM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Nothing new
these things have been around for quite a while. The offroad 4 wheeler guys use them on their mudder tires. Tech Supply in Kansas City has another brand. Or do a google search and read away.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 03:14 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Front wheel drive ?? ALANSD Airstream Motorhome Forums 14 08-25-2002 12:47 PM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
