Old 11-20-2010, 06:48 PM   #1
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Drawers come open when travelling
A few months ago I submitted a thread asking for help with drawers coming open when travelling. Someone suggested that I might try less pressure in the tires (I was running 70 psi in Maxxis load range E's and decreased it to 65 psi). Andy suggested installing Centramatics balancers - which I did. I just travelled Florida to Cape Cod and back without a single drawer coming open. Thanks guys for the great suggestions! They worked! What a great forum!
mhilley is offline   Reply With Quote
Old 11-20-2010, 06:53 PM   #2
x
XXXX , XXXX
Just a little humor. If your drawers are coming open while travelling maybe you need a new zipper. LMAO.
wasagachris is offline   Reply With Quote
Old 11-20-2010, 07:19 PM   #3
2000 34' Limited S/O
Jamestown , North Carolina
I also put Centramatics on mine a year ago and have had great results. Also, run 65 psi in tires.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 11-20-2010, 07:55 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We, too, have added Centramatics, and have noticed fewer things "moving" inside while traveling... just one more small thing to help the whole experience...
TB & Greg and Abbey Schnauzer
#3954
Old 11-20-2010, 09:00 PM   #5
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
OK to the unlearned, what are Centramatics? What do they cost? How do you install?
RichHog is offline   Reply With Quote
Old 11-20-2010, 09:10 PM   #6
Centramatics are tire, wheel, hub and drum balancers.
They slip over the studs on the drum, and then you reinstall the wheel.
There is nothing to twist, turn or adjust.
When the wheel assembly hits about 25 mph, everything becomes balanced. The Centramatics continuously adjust, to also compensate for tire wear.
We have a video of what it is and how it works, on our web site, but as a vendor, I don't believe I can post it.
Old 11-20-2010, 09:21 PM   #7
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Centramatics
Here ya go Rich..... watch the video !
http://centramatic.com/Page.aspx?page=Demo
Looks like a cool idea. I just installed a pair. If you can change a tire, you can install 'em. Haven't had a chance to give them a workout yet to comment on performance, but they make a cool swooshing noise ! Expect to pony up about $ 100 / pr + shipping.
Grab the phone number on the site and give Jerry a call, he'll fill you in and answer all your questions. Great service and fast shipping. Let us know how it goes !
T & K
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 11-20-2010, 09:23 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, here are a few pictures that might help you.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-20-2010, 09:36 PM   #9
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
wow, thanks guys. Was wondering what else I could spent money on.
I had the end cap wood panel past the shower come loose after maiden voyage home (2006 Safari FB). so wondering if there's a problem underneath in vibration.
Old 11-20-2010, 10:04 PM   #10
Loks like your shocks are upside down.
Old 11-20-2010, 11:00 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You might also check with Andy at Inland RV...he carries them and I believe they are on sale at the moment...that's where we got ours.
B4WEDI is right...if you can change a tire you can install them. I can and I did.
#3954
Old 11-20-2010, 11:51 PM   #12
Salem , Oregon
Images: 18
Originally Posted by Inland RV Center, In View Post
Looks like your shocks are upside down.
Hi, Andy. Two of my shocks were up-side-down from the factory, but as noted in my blog, Airstream took care of me and all is well now.
Name:	IMG_2041 (Large).JPG
2005 Safari 25-B
Old 11-21-2010, 12:47 PM   #13
2005 19' Safari
GLENDALE , AZ
As an aside, our Airstream had the nuts missing on the lower shock-mounting bolts. Not sure if they were loose and fell off or if they weren't installed at the factory, as I didn't notice until after a year.
By the way, Andy, will the Centramatics for 15-inch wheels also work with 16-inch wheels, or is that a different part number?
Thanks...
Old 11-22-2010, 10:49 AM   #14
Thanks...
Our special Centramatics fit a 6 lug wheel as long as there is a flat 10 inch surface on the backside of the wheel. Some Mag wheels do not have that much flat surface on the backside. Accordingly then, 15 or 16 inch, one in the same.
Drawers open while in transit mhilley Doors & Locks 15 10-08-2010 09:51 PM
Dropping my drawers... Bing-Bing Cabinets, Counter Tops & Furnishings 1 09-08-2009 04:54 PM
Need drawers! AluminumLuvr Interior Restoration Forum 2 04-30-2009 03:10 PM
Dropping my Drawers! Foiled Again General Interior Topics 1 04-28-2009 05:30 PM
