Old 10-23-2018, 06:24 PM   #1
wmb
2013 25' Flying Cloud
Springfield , New Jersey
Do I have Nev-R-Lube bearings?
Is there a way to tell (without taking off wheels) whether the Nev-R-Lube bearings are fitted on my 2013 Flying Cloud 25?
wmb is offline   Reply With Quote
Old 10-23-2018, 06:52 PM   #2
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Nope. Gotta take a peek
Old 10-23-2018, 09:35 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
http://www.dexterpartsonline.com/fil...20Bearings.pdf
>>>>>>>>>>>>>>>>Action
Old 10-24-2018, 05:41 AM   #4
Lakes Region , New Hampshire
If the axle still has the manufacturer sticker on it, you should be able to tell by the numbers on it, as they are made as a single unit to order. Usually middle of the axle and if Murphy put it on, directly on top.
"Anyone, who actually fought for it, would know that the freedom we fought for, was so no one could tell us what we have to do." -me
RandyNH is offline   Reply With Quote
Old 10-24-2018, 07:34 AM   #5
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
And if you look in the manuals that came with the trailer, there should be one for the Dexter axles. There should be 2 stickers on the inside of the front cover. These are the S/N for the axles that were installed in your trailer. Can call Dexter with this info and they can tell you what you have. At least this is how my Airstream came. Good luck, Mike
Mike S. is offline   Reply With Quote
Old 10-24-2018, 02:46 PM   #6
2Flyinginthecloud
2016 23' Flying Cloud
Edmonton , Alberta
Never lube bearings
My 23 FC does not have never lube bearings, I believe they are standard on the 25, check your manuals as suggested.
Thomasr is offline   Reply With Quote
Old 10-26-2018, 08:12 PM   #7
wmb
Thanks all. I was able to dig out the Dexter manual and there are indeed a couple of stickers inside the front cover. I fired off the question to Dexter and will wait for a response.
Pulling the hubs and bearings on a Nev-r-lube axle Jammer Wheels, Hubs & Bearings 11 12-04-2018 04:06 PM
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 05:48 PM
Does a 2012 19 foot flying cloud have nev-r lub bearings scamp Wheels, Hubs & Bearings 5 03-17-2014 01:12 PM
centramatics and nev-R-lube bearings gtc6452 Wheels, Hubs & Bearings 14 08-09-2013 10:59 AM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 08:40 PM
