Old 11-17-2010, 08:35 PM   #1
bennyg's Avatar
1973 23' Safari
New Albany , Indiana
Did I screw up on this purchase?
I have a 1973 Safari 6 lug, and I measured my wheels after i made this spontaneous purchase, and they are 16". i purchased a set of (4) 15" wheels and tires from a 2005 safari from ebay. i really liked them and thought if they wouldnt work i should be able to re-sell them! but i really hope they will work. here is the link for the wheels. thanks to all in advance for any input!
Airstream Tire and Wheel Assy USED Set of 4+1 Load E - eBay (item 270662981239 end time Nov-17-10 09:49:20 PST)
Ben
bennyg is offline   Reply With Quote
Old 11-17-2010, 08:49 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
I believe your 73 AS came equipped with 15 inch wheels when new...
The 2005 alum wheels should fit fine on your AS - I don't believe the pilot hole has changed...
How are the axles on our 73? Have they been changed? I had to install new axles in our 78 due to age - the rubber rods inside the beams had hardened over the years an no longer articulated properly - new axles got our 'baby buggy' ride back - the only way to go!
If you have to replace your axles, you can insure you get the proper hub/drums that fit you new alum wheels...
Ray
Ray & Pat; Morada, CA
Old 11-17-2010, 08:51 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Those should work fine,I had them on my watch list,then forgot about them.Put them on and enjoy. Dave
easyride is offline   Reply With Quote
Old 11-17-2010, 08:53 PM   #4
bennyg's Avatar
1973 23' Safari
Ray
I am definitely in need of new axles, I will be getting those soon. Where did you get your axles? Thanks for your help
Ben
Old 11-17-2010, 08:59 PM   #5
x
XXXX , XXXX
Ben you should be fine. Your 73 was originally equipped with 15" wheels.
wasagachris is offline   Reply With Quote
Old 11-17-2010, 09:08 PM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
I bought our axles from Inland RV out here on the 'left' coast...check the forums here, there's tons of info about axles, and you are far closer to the axle mfg's in the mid west...
They are easy to change, I posted some info when I did ours - you do them one at a time, with the trailer up on some 8 inch ramps for clearance underneath, etc...check the forums...
My post is here - look at post#18... http://www.airforums.com/forums/f173...tml#post917400
Ray
Old 11-17-2010, 10:02 PM   #7
x
XXXX , XXXX
Andy can have them drop shipped to you.
Old 11-17-2010, 10:42 PM   #8
1973 31' Excella 500
Spring Green , Wisconsin
Very good purchase Ben. Like I told you last night when we talked, I thought your tires looked "big". I never noticed they were 16" though. I think you got a good price, too!
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 11-18-2010, 07:53 AM   #9
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
bennyg, if your back plates, brakes and drums are still good you can get your axles rebuilt in Elkhart IN for less than $100.00 and if you let them know you are coming they will do it while you wait.
Or the price I was quoted for two new axles with brakes in 2008 was $600.00
Read about my axle adventure here: http://www.airforums.com/forums/f437...ild-46697.html
Talk to Kevin Fort at Axis Products 574-266-8282
Bruce,
Parts needed: Sink for rear bath Tradewind
My blog for the 1975 Tradewind restoration
bmklawt is offline   Reply With Quote
Old 11-18-2010, 08:37 AM   #10
Bruce,
Since it's been two years since you had your axles rebuilt, and there seemed to be a question about the limited travel on the torsion arm, can you give us an update on their performance? Have you completed your interior work and travelled with the trailer? How much travel was there in the torsion arms after completing the interior work? Thanks.
Lew TAC #WI-6
Old 11-18-2010, 08:48 AM   #11
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Ben
Dont put off the axles if you want OEM. Call Andy at Inland RV and set it up. You can pick up the axles at the factory.I did. But you must act quickly because at last report Henshen/ GKN is due to close the Jackson Center,Ohio plant by the first of the year. Then you will be forced to go with Dexters. I have no presonal experience with Dexters and Im sure they are a quality axle because Airstream is using them on all new units,but there have been instances of problems in measurements and confusion on what number axle to buy and then there are the holes to be drilled because they are not direct bolt in as are Henshen/GKN.
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-18-2010, 03:21 PM   #12
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
driftless, There is about 1-1/2+" travel in the torsion arms sense I have complete the interior.
I traveled to Yellowstone from Michigan last year and spent a month there, put about 6000 miles on the trailer that trip.
It towed like a dream, I have no sway control and had no problem with sway, I drive as fast as I can and have gotten up over 110MPH and cruise at 90MPH when I can with out problems. Everything in the trailer stays put and I can see no ill effect on the trailer from the new axles, no sheared rivets.
I travel with the black and gray tank empty and the water tank completely full or completely empty.
I would buy new axle's from from Axis Products Main again, in fact I bought a 1966 Globetrotter this year and had Axis Products Main rebuild that axle.
Bruce,
Old 11-25-2013, 09:42 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
great idea on the rebuild, Sure saves some $$. MIght have to take mine off and drive up to Elkhart. How long does the rebuild process take?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-25-2013, 11:28 AM   #14
1976 31' Sovereign
Oswego , Illinois
Smile Axles
Ben
I pur mine for 76 sov. from Colin Hyde Restorations perfect fit made in Indiana exc.communications, no drilling etc. just bolt up, he has all specs. no"s ex. what you need, he is on forums.
Old 11-25-2013, 02:50 PM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
On this 3 year old thread -
To my knowledge Axis is no longer doing business.
Axles prior to the 60's and 1969 models sticks into my mind, require modifications to be installed.
>>>>>>>>>>>Action
Old screw woes sumsmug General Repair Forum 13 08-27-2010 06:33 AM
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
Help me screw this up..... Spice Rack Gator113 General Interior Topics 8 05-14-2010 08:27 AM
Caulk the old screw holes?? Tidal Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-30-2007 03:46 PM
