Old 01-23-2017, 07:57 AM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Dexter Never-R-Lube Inspection and Maintenance
Going through my trailer this winter in detail, as it is a 2015 with approx. 20k miles or less, it is in good shape.
One area Id like to pay attention too are the axles, hubs and brakes. I cannot find much on the internet or from the Mfr on inspection and maintenance. It seems like more of a "wait till they fail" (presumably after many miles) and then replace.
Is there really no maintenance or a way to inspect these things?
Ted S. is offline   Reply With Quote
Old 01-23-2017, 08:08 AM   #2
dznf0g's Avatar
Oswego , Illinois
About the only way to regularly check the Nevr-lubes is to get an infrared thermometer and shoot them at fuel stops. Whenever you have the trailer jacked up, rock the tire and wheel to feel for excessive clearance....that's it.
-Rich-
Old 01-23-2017, 09:13 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Ted, we route our 2012 FC 25 through Jackson Center Service every two years where they pull and rotate the wheels, check the brakes for condition and wear, and check the Never-Lube Bearings for "runout", which I believe is checking them for excessive wear. I've seen an inspection period for this, either in the Airstream or Dexter Owners Manual, which prompted us to have it done.
Doug and Cheryl
Old 01-23-2017, 10:21 AM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Our as with the neverlube bearings,has 22000 miles and they are still going, they should run maybe a 100,000 miles..
Old 01-23-2017, 10:36 AM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
That and if you have Nevr-lube axles, you probably have self-sdjusting brakes. Good to pull the wheels every two years to inspect. I had one wheel that was not braking because the self adjuster was bent. Stops better with all wheels braking!
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 01-23-2017, 11:26 AM   #6
dznf0g's Avatar
Oswego , Illinois
....Or E over H disc brakes, which should still be inspected every couple years ( or every year, if you're a high miler.
-Rich-
Old 01-23-2017, 01:10 PM   #7
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I bought my 2010 FC used and I am pretty sure it has the never lube axles. I did not trust that though. I decided to pull mine apart, re-packed them, and put new grease seals on. It takes a huge socket and one of mine had some very minor wear on the axle where it did not have enough grease. I do not regret servicing mine as it probably would have failed at some point. I imagine many people would not agree with me for servicing them though. Also, I highly recommend getting new preloaded brake packs (already have the pads, springs, adjusters, etc. on a mounting plate) and replace them at the same time. They are pretty cheap and very easy to change out once you have the wheels pulled off.
Echelon73 is offline   Reply With Quote
Old 01-23-2017, 01:17 PM   #8
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
I took delivery on our, new to us, trailer March 2015 from Airstream Adventures Northwest in Gladstone, OR . Loved the no maintenance wheel bearings, suspension, self adjusting brakes, etc. At approximately one year, 5K miles, had one wheel lock-up during a hard braking event. It destroyed the tire, with new looking tread, taking the tread completely off the dragged spot . AS Adventures NW said it was not a warranty issue as I should inspect the brakes for correct adjustment. My view is that on delivery all brakes were inspected and should have automatically adjusted correctly going forward but this one over adjusted causing it to lock-up. Either that or the other brakes did not adjust correctly and only the one brake took the load causing it to lock the wheel. Naturally they did a song and dance saying all the wheels showed brake dust so they were working and it was my responsibility. End of story they refused to admit malfunction so going forward I will not trust the auto adjusting feature and inspect for correct brake adjustment on a quarterly basis.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 01-23-2017, 01:20 PM   #9
2017 30' Flying Cloud
Spotsylvania , Virginia
I was told that on my 2017 FC the "Never Lube axles" had sealed bearings so the only way to check them is to jack it up and rock the wheel assembly back and forth.
KWN306 is offline   Reply With Quote
Old 01-23-2017, 01:30 PM   #10
dznf0g's Avatar
Oswego , Illinois
You probably have EZ-Lube bearings, not Nevr-Lubes. Nevr-lubes cannot be disassembled and re-packed.
-Rich-
Old 01-23-2017, 01:31 PM   #11
dznf0g's Avatar
Oswego , Illinois
Correct
-Rich-
Old 01-23-2017, 01:44 PM   #12
dkottum's Avatar
Here is a sheet on the Dexter Nev-R-Lube bearings, including warning to use zero offset wheels and inspection intervals and procedures.
http://www.dexteraxle.com/i/u/614960...e_Bearings.pdf
Doug and Cheryl
Old 01-23-2017, 01:58 PM   #13
rastapoodle's Avatar
2004 31' Classic
Middle River , Maryland
Do these never lube axles have outboard brake drums ? Brake drums that can be removed without disturbing bearings , if not how hard is it to remove drum/bearing assembly.
rastapoodle is offline   Reply With Quote
Old 01-23-2017, 02:00 PM   #14
dznf0g's Avatar
Oswego , Illinois
Yes the bearing set is pressed into the drum. Removal of the drum is just like any other drum, but the bearing set and drum just slide off the spindle.
-Rich-
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 05:48 PM
Dexter nev-r-lube failures Jammer Wheels, Hubs & Bearings 44 04-26-2015 08:42 AM
Dexter Never Lube axles boomerang1 Axles 1 07-21-2012 08:59 PM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 08:40 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 05:35 PM
