Old 10-14-2010, 10:25 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Dexter nev-r-lube failures
Just had a seal failure on my nev-r-lube bearing. Apparently they're filled with oil. It's dripping out.
They are supposed to last longer than 2500 miles, aren't they?
Old 10-15-2010, 12:12 AM   #2
Halimer
2006 25' Classic
New Hyde Park , New York
I don't have the Dexter manual at hand, but I believe the warranty is 5 years.
Mark
halimer is offline   Reply With Quote
Old 10-15-2010, 04:43 AM   #3
Baltimore , Maryland
Jammer you are having a string of bad luck with that trailer. I thought a vintage rig keeps the tool box dust free, but that rig of yours is putting you to the paces. They should be filled with grease, not oil.
Old 10-15-2010, 07:55 AM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I believe 2010 or maybe 2009, is the first year they were used, so there won't be much of an experience base. Mine have about 8,000 mi with no problem. Where is the oil showing up?
Ken
Old 10-15-2010, 08:01 AM   #5
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
My '08 has the nev-r-lube
no probs
boondockdad is offline   Reply With Quote
Old 10-15-2010, 09:55 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
It's working its way out from the dust cap in the center of the wheel and then kinda drips down the wheel and over the tire. I haven't pulled the drum and have no idea what things look like in there.
62overlander there have been six problems I would characterize as serious. The thermostat wire that wasn't connected, the refrigerant line that was rubbing on the housing, the black tank sensor, the water pump, the tail light, and this. Other than that it's just been fit and finish problems, latches, interior lights, that kind of thing. I don't think that's unusual, from what I've read, for people who actually use their traylah and take it on the road and stuff.
Old 10-15-2010, 10:54 AM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Jammer
I'd pull the offending hub or hubs and clean and check the bearings. I'd almost bet you have a bad one. Its getting hot and the grease is getting to its drip point and seeping out.
If ya can't, Id get it to a dealer for warranty service and if no warranty service is available Id do it myself,You cant afford to lose than spindle.
GOOD LUCK
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 10-15-2010, 10:55 AM   #8
Ag&Au's Avatar
no probs
I guess they been around longer than I thought.
Old 10-15-2010, 11:01 AM   #9
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
just a bit too much grease in a closed cavity can expand and push
through....may not be a "failure" - take the cap off and check it.
Remove a bit of the grease from the cap and wipe the mating surface
of the cap clean and put it back on. It should be fine, if not just get a new cap.
kennethowens is offline   Reply With Quote
Old 10-15-2010, 11:31 AM   #10
Ag&Au's Avatar
Not the same
There seems to be some that do not realize that the Nev-R-Lube bearings are not constructed in the same way as convention trailer bearings.
One important difference is that there is no regreasing and no repacking involved.
The file attached to post #1 on in this thread: http://www.airforums.com/forums/f465...ion-70117.html - has a lot of good information and diagrams.
Regards,
Ken
Old 10-15-2010, 11:35 AM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If I recall correctly, drip point on wheel bearing grease is high enough so that the bearings are much too hot—something like 350˚ or 500˚. Ken, do you mean there's no grease in the bearings or you don't have to grease them?
Gene
Old 10-15-2010, 11:39 AM   #12
Dearborn , Michigan
Images: 21
from Dexter user manual: "NOTE: A slight amount of grease weeping from the seal area is normal. Excessive leakage may indicate abnormal bearing operation."
Old 10-15-2010, 11:52 AM   #13
Ag&Au's Avatar
Gene
I actually edited the post since I said that.
There is some grease, but in is not field replaceable.
Ken
Old 10-15-2010, 12:23 PM   #14
1975 Argosy 24
Malakoff , Texas
What is the hand-touch temp of the hub after towing a while.
If the hub is Very hot - the hub is too tight causing the over-heating.
That hub went on and it can come off!!
The best Dexter or anyone else can do is put a seal front / back to keep
contaminates out and the grease in. Tighten the hub too much and the
grease gets hot.
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 04:35 PM
Dexter 'Nev-R-Lub' or Regular Bearings halimer Axles 3 07-01-2010 01:36 PM
Jackpot Nevada RV parks??or Wells Nev? J Goertzen On The Road... 1 08-31-2008 09:26 AM
