Old 04-25-2015, 09:27 PM   #43
2007 22' International CCD
Nothing quite so useful as a good selection of BFHs!
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 04-26-2015, 07:35 AM   #44
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Maybe I'm old fashioned but I don't believe in " lifetime" lubrication of anything in the automotive industry. It certainly is time consuming to do it and it may be expensive to have someone else do it but I vote for standard bearings and periodic inspection and
re-packing. It requires that you remove the drums so you get to inspect your brakes while at it. To me that is the BIG PLUS. Whether you do it every year, every 10,000 miles or at a longer interval the important thing is that you DO IT. AND another plus is I can replace a failed wheel bearing on the side of the road or at a campsite in a pinch. You can't do that with a sealed unit.
See ya'll on the road sometime. Hopefully not with a bad bearing.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-26-2015, 07:42 AM   #45
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
For people wanting to upgrade to discs, Kodiak does indeed make a rotor that works with Nev-R Lube bearings.
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 04:35 PM
Dexter 'Nev-R-Lub' or Regular Bearings halimer Axles 3 07-01-2010 01:36 PM
Jackpot Nevada RV parks??or Wells Nev? J Goertzen On The Road... 1 08-31-2008 09:26 AM
