Old 08-17-2010, 01:12 PM   #1
dznf0g's Avatar
Oswego , Illinois
Dexter Disc equipped axles never-lube bearings - maintenance
Do all the Dexter Disc equipped axles have never-lube bearings? I havent had my wheels off yet, but my owner's manual says "clean and repack". I have an 07 Classic 30. Nickmaloy says his 06 Classic 30 is sealed???? Guess I could pull one down, but thought a quick answer might be had here. Thanks.
Old 08-17-2010, 01:22 PM   #2
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Never Lub Hubs
Here is a copy of the Dexter service/maintenance manual. The never lub hubs begin on page 55. This manual includes part #s for seals, bearings and the recommended lubricants.
fltlevel510 is offline   Reply With Quote
Old 08-17-2010, 01:23 PM   #3
Dexter Manual
Sorry,
Had a little problem with the attachment
Old 08-17-2010, 01:28 PM   #4
Dexter Manual
OK,
I think the file is to big, so here is a link to the manual.
http://www.towmaster.com/pdf_manuals...00lb_axles.pdf
Old 08-17-2010, 04:35 PM   #5
2007 25' Classic
dznf0g,
I have an '07 Classic Limited 25 with factory discs and Neverlube axles. My manual also describes repacking bearings in detail and other stuff that doesn't pertain to my trailer. I suggest either 1) pull a wheel and see which bearings you have or 2) call Airstream with your VIN at hand and they can tell you if you have the Neverlubes. Being lazy, I took the second option.
I bet you have the NeverLube axles...
Ray Herrold is offline   Reply With Quote
Sealed Bearings and Disc Brakes nickmeloy Wheels, Hubs & Bearings 9 07-15-2010 11:24 AM
Dexter 'Nev-R-Lub' or Regular Bearings halimer Axles 3 07-01-2010 01:36 PM
Disc Brake Maintenance Steve & Mary Brakes & Brake Controllers 7 12-14-2009 11:06 AM
New axles - lower-maintenance bearings? mutcth Axles 28 11-26-2009 05:11 AM
Axle replacement - Dexter #10 w Disc brakes vs original FrenchBern Axles 27 05-22-2008 11:23 AM
