Old 04-12-2015, 10:07 AM   #1
1997 30' Excella
Corpus Christi , Texas
Cracked wheel
Is this safe to drive on? When should this be replaced?Click image for larger version
Name:	ImageUploadedByAirstream Forums1428854813.957010.jpg
Knudsvig is offline   Reply With Quote
Old 04-12-2015, 10:10 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
If it's only on one wheel on a trailer with double axles you are probably safe driving home but keep your speed down (perhaps avoid the interstates.) If you don't have a double axle trailer, I would not drive on that at all.
I would replace all rims and tires immediately upon getting home.
Best of luck.
Bob Martel
WBCCI# 5766
Old 04-12-2015, 11:36 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
From the rust in the crack it looks like it has been there a while. That portion of the wheel will not effect tire pressure. So while I would drive on i I would not plan any "Trips" before replacing it.
I would be far more concerned if the crack was around the bolt pattern or in the rim portion of the wheel.
Upon re-inspection is that a second crack at 7 o clock?
2004 Excursion 4x4
Old 04-12-2015, 11:38 AM   #4
1997 30' Excella
It's a double axle. Does anyone know if Ron Hoover in CC could do wheel replacement?
Old 04-12-2015, 11:49 AM   #5
1997 30' Excella
Southwest wheel in corpus has the wheels. Should I replace all 4?
Old 04-12-2015, 11:50 AM   #6
1997 30' Excella
It has 2 cracks and the one at 11 is worse than the other
Old 04-12-2015, 12:42 PM   #7
HowieE's Avatar
Images: 12
If you deviate from the original wheel, do something flashy, make sure the new wheels have the same Off Set and are rated with enough weight capacity for you trailer.
The Off Set is what centers the wheel in the wheel well, in and out. Too often overlooked when buying wheels and problems can occur.
2004 Excursion 4x4
Old 04-12-2015, 01:33 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Cracked wheel
I would get that wheel off asap.
The crack says to me that the center section of the wheel is separating from the rim portion CAUSING the visible cracks.
Those cracks were caused by metal fatigue induced by the wheel center moving relative to the rim portion.
My guess is that the welds holding the center to the rim are failed throughout the large area between the cracks, while the small area between the cracks is still welded in place... For now.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-12-2015, 02:31 PM   #9
1997 30' Excella
Bwoodtx told me it is a common failure in 1997 classic
Old 04-12-2015, 05:29 PM   #10
1997 30' Excella
Made it home
Old 04-12-2015, 06:54 PM   #11
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Hey Guys! Dave & Cathy here. Good to meet you at the rally, and glad you got home safely. Hope to see you in Rockport.
Cannonball is offline   Reply With Quote
Old 04-13-2015, 07:05 PM   #12
1997 30' Excella
Thank you Dave and Cathy! Great to meet you guys!!
cracked wheelwells Chas Wheel Wells 20 10-02-2007 09:22 AM
Cracked Front Wheel Rotor LALandyacht Mechanics Corner - Engines, Transmission & More... 2 03-18-2005 05:39 PM
bent/cracked rib? Jabba Ribs, Skins & Rivets 1 10-27-2002 06:04 AM
Cracked door frame 77caravaner Doors & Locks 5 10-11-2002 06:43 AM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 12:48 PM
